My bob is still stuttering
Old Jul 25, 2020 | 08:10 AM
  #31
LonestarXL's Avatar
LonestarXL
Originally Posted by falikmike
i am disapointed by my harley, really am....people say harleys break down and it is true......i have it now for 4 years or 3 years not sure and nothing was wrong....but this year, spokes broke, rear brake switch is broken and now this stuttering.....i thought i will have no problems for years and years....
It’s a 6 year old bike. I don’t know how many miles you have on it but 6 yr old bikes of any make can begin to have minor issues that need attending.
Especially ones that have had tuners and aftermarket performance parts installed. It’s just the nature of the beast.
I know how it seems to all come at once, it does for me at times, but running it down and getting it sorted is a good feeling. Good luck and hope you find the cause.
PS—-don’t ever pressure wash your bike!
Old Jul 25, 2020 | 09:04 AM
  #32
falikmike's Avatar
falikmike
i will not pressure wash my bike again, maybe that was not the reason at all anyways......
i narroved it down to
-speed control sensor
- cables
-fuel cables
-throttle control sensor....
Old Aug 2, 2020 | 11:09 AM
  #33
falikmike's Avatar
falikmike
Just to give update I fixed it today I think, it runs smooth af, smooth at idle, no more decel pop, the decel pop decreased for like 98%, almost not happening anymore.....
I changed the sparkplugs to original Harley sparkplugs....before I had some japanese inside NGK or something.....they were black and one had to much gunk on it, so much deposit, so I guess that is why I had constant misfire, decel pop etc......
I tried so many things, suspected so many things, next would be unpluggine the speed sensor, check for leaks in valves etc....but it was the simplest and the cheapest thing, spark plugs....
GUYS always run Harley spark plugs, they are cheap and great.....it runs now like new....I am extremely happy now...
Old Aug 2, 2020 | 12:00 PM
  #34
GREENOHAWK69's Avatar
GREENOHAWK69
Maybe try a Jim, they stutter less.
Old Aug 2, 2020 | 01:40 PM
  #35
seniorsuperglideE8's Avatar
seniorsuperglideE8
If you clean the IAC again use a MAP sensor cleaner to clean that little valve , less harsh on the components inside the throttle body. My self I would cycle the ignition a few times while cleaning the IAC and open the throttle plate and clean the inside of the throttle body, inside top and inside bottom. Also think about installing an External Breather System to divert the oil vapors from going into the throttle body to gunk everything up again.
Old Aug 2, 2020 | 02:17 PM
  #36
falikmike's Avatar
falikmike
i have special throttle body spray now....but they say it will eat the paint away....so I am a bit scared to use it a lotč
if I spray it inside will that go into the engine? if I open the throttle so the flap opens up and spray inside everywhere? This goes to engine right?
Old Aug 2, 2020 | 04:44 PM
  #37
Tileman2692's Avatar
Tileman2692
Get external breaths also . Got that hot oilie fumes from the heads going right into the carb.
Irishcowboy300
Electrical/Lighting/Alarm
Jul 22, 2019 09:02 PM
baba booey
Jun 23, 2015 09:24 PM
gdillon86
Jun 9, 2013 01:28 PM
baldu
May 5, 2009 04:40 PM
bzelick
Aug 19, 2008 11:20 AM
