Is this a good Dyno or not????????
Old Jul 27, 2007 | 01:11 PM
grueter's Avatar
grueter
Default Is this a good Dyno or not????????
Dynojet Research How do you know if you got a good dyno test or not? 2006 Wide Glide Vance&Hines (BIG RADIUS), Power Commander and Arlen Ness (BIG SUCKER)Air Filter Max Power = 68.01 Max Torque = 74.02 . Is this Good or Average? Help me Thanks
Old Jul 27, 2007 | 02:03 PM
carpetride's Avatar
carpetride
Default RE: Is this a good Dyno or not????????
ORIGINAL: grueter
hard to say... if you didn't do a stock run on the same dyno under the same conditions first it's hard to judge the results. IMO I would say thats about average for a TC88. At my dealerships dyno I got 70 max power and 75.5 max torque with just adding lower restriction slippons. most factory stock numbers are around 60hp and 70 tq. at the rear wheel give or take a couple.
Old Jul 27, 2007 | 03:16 PM
Trotter's Avatar
Trotter
How does the bike run ? Any popping, Backfire, Hesitation, Surgeing, what's the A/F numbers ?
Old Jul 27, 2007 | 09:18 PM
Mascman's Avatar
Mascman
My brother and I just had our Dyna's done.
His 2006 Superglide with V&H big radius, Screamin Eagle backing plate with K&N, PCIII:
75HP and 79 foot lbs of torque
My 2006 Street Bob with Python 2-1 and all else the same as his:
76 HP and 79 foot lbs
Can't remember the decimal point values, but I had more ft lbs of torque.
Both our bikes run strong.
I think your numbers should be better.
Did you have them bump up the Rev limiter?
Old Jul 27, 2007 | 10:05 PM
Cabo's Avatar
Cabo
Your HP number could be slightly better however I think those Big Radius pipes arnt helping you much.
Old Jul 28, 2007 | 12:48 AM
low06's Avatar
low06
'06 low rider with vance and hines straight shot slip ons, pclll and screaming eagle air cleaner: 77 hp, 80 lbs ft.
Old Jul 28, 2007 | 03:45 AM
Mascman's Avatar
Mascman
ORIGINAL: Cabo
My brother has the same pipes and it is making almost as much as my 2-1 pipes.
I think either the Big Sucker is holding you back or the Dyno guy just isn't that good.
I'd tell him the numbers everyone is gettting and ask if he can try to tweak it some more.
Old Jul 28, 2007 | 08:11 AM
hksb's Avatar
hksb
I am adding V and H short shots staggered and an AH big sucker with Pc3. Can anyone suggest where I can get a map for this? or will the PC3 remap itself?
Old Jul 28, 2007 | 11:12 AM
Mascman's Avatar
Mascman
www.PowerCommander.com
The PCIII does not automatically adjust...it is a closed loop program.
I'm assuming you have a Street Bob, but what year?
Old Jul 29, 2007 | 05:24 AM
kensim's Avatar
kensim
i thought u would get than that
