Accessory fuse blowing
Old Sep 13, 2020 | 09:09 AM
jb4507hd's Avatar
jb4507hd
4th Gear
Default Accessory fuse blowing
my accessory fuse keeps blowing. I have disconnected the the front turn signal as well as the rear and it still pops every time. The previous owner put in rear led lights witth running lights, so t thought that was the problem. But when i disconnected the wiring harness it still pops. I have been checking for a stray wire grounding but everthing looks good. I am at a loss , don't know what to do to try and isolate the issue and fix.
Old Sep 13, 2020 | 09:50 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You must tell us what you are working on....
Old Sep 13, 2020 | 10:05 AM
jb4507hd's Avatar
jb4507hd
4th Gear
Sorry, I have a 2006 dyna street bob. Any time I hit the right blinkers the accessory fuse pops. The left side works fine but right side not at all.
Old Sep 13, 2020 | 10:12 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Where are you disconnecting the harness at? Disconnect the battery. Now pull the fuse and with your DC/OHM meter set on resistance,one lead to ground, probe the each side were the fuse plugs in and see if it shows on the meter.
Old Sep 13, 2020 | 10:47 AM
jb4507hd's Avatar
jb4507hd
4th Gear
I am disconnecting the aft harness under the seat. It goes
Old Sep 13, 2020 | 10:52 AM
jb4507hd's Avatar
jb4507hd
4th Gear
I disconnected battery and pulled fuse put multimeter on there and got 0 ohms
Old Sep 13, 2020 | 11:08 AM
jb4507hd's Avatar
jb4507hd
4th Gear
Correction I got 982 when grounding from frame
Old Sep 13, 2020 | 11:18 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Unplug the TSSM.
See if the fuse blows when you press the R/H turn signal button.
If the fuse still blows, you will know that the short is in the wire that runs between the TSSM connector and the R/H turn signal switch (White/Brown wire).
Old Sep 13, 2020 | 11:58 AM
jb4507hd's Avatar
jb4507hd
4th Gear
Copy . Wilco. Thanks for your help
Old Sep 13, 2020 | 12:11 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Let us know what you find.
