Should I Go Chain Drive?
Old Nov 19, 2020 | 08:22 PM
TwiZted Biker's Avatar
TwiZted Biker
Yeah I though I was building a monster motor and need a chain and besides the $350.00 cost it was a pain in the *** to keep lubed and adjusted. I went back to an S&S 1 1/8" belt and never had an issue with breakage. Set to 1/4" at 10 lbs. I'm only 114 tq and 111 hp. I did break 2, 1" belts but that was because I set the tension to 1/'2 " at 10 lbs... TwiZted suggested I set it to 1/4" and I'm still good. I have a set up I will sell you if you want for $200.. I'll never use it again. Like new D.I.D. chain with I believe a 23/51 sprockets.. And trust me I did not baby my bike... BUT what I did do was shear my crank pin...
I spun the compensator shaft in the flywheel on my 88" shovel while running dual belts, 200' of solid black line from the burn out with the dogleg when I hit second, rode it a 130 mi. home before it gave it up.
I've broken chains too, if your lucky they'll just spit out the back and trash the chain guard. If your not say goodby to big ticket items like primary covers, starter housings or a split trans case if Murphy decides you need a lesson. Been there did that......
Old Nov 20, 2020 | 07:53 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Yeah Yeah really using your bike for what it was built for can be quite disastrous...
Old Nov 20, 2020 | 08:09 AM
IronAss's Avatar
IronAss
When I was competing in trans continental endurance events I converted my 05 to a chain drive. As long as you stay in top of it, it’s fine.
Tom84FXST's Avatar
Tom84FXST
It was "built for" 64 hp...
I run a chain as that's what my 84 came with...run an o-ring, and never lube it, so the bike stays clean...inspect it about once a year, and replace it when any rollers show any roughness...
sprockets can make it though quite a few chains if the rollers never lock up...IMO lubing an o-ring chain just attracts dirt, and makes it wear faster...
Old Nov 20, 2020 | 11:06 AM
TwiZted Biker
That's ugly, that a first for me, never seen one snapped like that.
Old Nov 20, 2020 | 11:20 AM
98hotrodfatboy
Apologies to the OP, didn't mean to get carried away..
Believe it or not it still ran, I was drunk as hell and said F it.. Drive home a mile and a half and then the next morning I drove it to the shop five miles.. I was shocked that I could still turn the other side of the crank and run the cam and lifters and all that.. Didn't even pop a valve on the piston...
Old Nov 20, 2020 | 11:32 AM
TwiZted Biker
Crazy what they'll do sometimes, mine I rode all the day after that morning burnout clowning all the trailer queens doing chirpies in the parking lot, rode it home the next day, let her sit 2 days for work, went to start it and nothing. Dropped the inspection cover figuring the primary belt had popped and nope it spun when I hit the starter but the engine didn't. Uh-oh.........
Old Nov 20, 2020 | 11:43 AM
98hotrodfatboy
It is amazing how it could continue to run.. I wonder if a TC could do that...The biggest problem with mine was that I was running close to 97 hp 97 lb of torque on a 83 inch Evo stock crank, but the real culprit was no compensator and chain drive on the rear so there was nothing to really absorb the hammering on the crank pin... And man I got to tell you, I loved doing quarter mile runs still smoking the tires in third gear.. It was awesome... Kind of well worth the breakage.. Sort of.... Lol....
Sauraus
Jan 10, 2025 04:23 AM
SpaceClown
Aug 24, 2020 09:25 PM
MadMario111
Jan 29, 2020 06:58 PM
Machine249
May 16, 2012 05:05 PM
megametalknot
May 17, 2011 04:34 PM
