Should I Go Chain Drive?
Old Oct 13, 2020 | 12:52 PM
AntCrow's Avatar
AntCrow
5th Gear
Default Should I Go Chain Drive?
Hey fellas,
I am planning to upgrade my Stock 88" Dyna Super Glide to a 97" or a 100" this coming winter.
My question is, should I also upgrade from the stock belt drive to a chain?
Also, I plan to use the S&S kit to upgrade. It comes with a cam chain tensioner and cams. What else should I upgrade?
Thanks for you time.
Old Oct 13, 2020 | 03:21 PM
Bob_fxdb's Avatar
Bob_fxdb
Brake and suspension
Old Oct 13, 2020 | 03:47 PM
brownie4412's Avatar
brownie4412
After the time spent , money wasted and headaches that came with the chain drive I had on my ‘04, I wouldn’t recommend it.
I get the look and the cool guy dyna thing (that’s why I did it), but if you’re thinking about doing it strictly for performance I’d say it’s not worth it. There’s plenty of 130hp bikes running around with stock belts on them, no issues. If you want the look (gold chain chrome sprocket sorta thing) then go for it because they do look bad ***.
Old Oct 13, 2020 | 08:45 PM
Bob_fxdb's Avatar
Bob_fxdb
Overall I can’t stand behind that statement. It depend on how you ride. If you gonna cruise and take it easy(by easy I mean minimal on hard acceleration from near zero or clutch dumping), you’ll be fine with belt. If riding HARD and using the full available torque, belt will not be strong enough, even with small engine upgrades. Go with chain if you have the chance and ride without worrying.
Old Oct 15, 2020 | 11:23 AM
brownie4412
Well, FuelMoto retained the stock belt on their 153hp Street Bob, that's good enough for me. Also, my 131/135 LRS has 12k hard miles on the original belt. Hopefully I'm not just lucky. We'll see though.
Old Oct 15, 2020 | 12:08 PM
Coverdog's Avatar
Coverdog
Isn’t Harley using belts on the new 131?
Old Oct 15, 2020 | 12:27 PM
Bob_fxdb's Avatar
Bob_fxdb
that’s good for you!
Rhetorical question(I don’t have interest in knowing your answer, no disrespect):
What is hard miles for you? Do you think you put enough stress on the belt on your riding style?
A perfectly healthy belt is good and strong, no doubt, but a small tear could end its life.
You need to take in mind that belts are made out of reinforced rubber, and rubber flex. Power loss right there. It’s just a shame if one are upgrading their engine for power and lose the gains right there. The throttle response is better also.
Im not hating on belts and I like the maintenance free aspect of them. If belts could be near as strong and has the performance of chain and super easy to replace on the dyna(primary) I for sure gonna switch back to belt.
Old Oct 17, 2020 | 11:31 AM
TOE_CUTTER's Avatar
TOE_CUTTER
Whether or not to convert depends on how you ride. If you’re going on trips (800+ miles), leave it with a belt. If this bike is your local in-town hot rod, put a chain on. For your power level, a chain is not required.
Dave
Old Oct 20, 2020 | 07:57 PM
frnchmn11's Avatar
frnchmn11
Stage I
I'm putting an S&S V124 in my 98 FLSTF and I was wondering if I should change my belt to a chain drive. I just don't want to deal with the maintenance but it sounds like I may not have a choice. I could go with an S&S V111 but Ive always wanted a 124.
Old Oct 20, 2020 | 09:49 PM
Suede Blue Man's Avatar
Suede Blue Man
Originally Posted by AntCrow
...My question is, should I also upgrade from the stock belt drive to a chain?
No, I don't believe you should, I don't believe it is necessary. Those belts are damn strong, weigh less than chain, are quieter than chain, are cleaner than chain, are maintenance free 'cept for periodic adjustment, and if anyone claims of breakage ask for proven/verifiable statistics/proof.
...What else should I upgrade? Wholeheartedly agree with Bob-fxdb on this, start with great rear shocks.
Our pleasure
Agreed!
I had two BLT's for dinner!
