pc111 ?
Old Jul 28, 2007 | 04:54 PM
06 lowrider's Avatar
06 lowrider
Default pc111 ?
can any1 aswer this i had a local custom bike shop install my pc3 and i guess that would of been pretty simple for me to do on my own but i didnt should my pc have come with some cords to hook up for the down loads cause the shop didnt give me any . and i keep reading about o2 eliminators what is that and should i have that with mine cause my sensors are hooked up i have big shot staggered thanks
Old Jul 29, 2007 | 11:10 AM
06 lowrider
Default RE: pc111 ?
any1 have any experience with theses pc111 do they have dials on them to adjust any help would be great mabe this is a thread that is talked about in here ill try a search
Old Jul 29, 2007 | 11:37 AM
TOMMAY's Avatar
TOMMAY
Default RE: pc111 ?
You should have a cord,the same kind that comes with digital cameras,only longer. The O2 eliminators (at least on my 06)are capped off at the end of the wire away from the exhaust so it appears they are still connected.
Good Luck
Tom
Old Jul 29, 2007 | 12:04 PM
06 lowrider
Default RE: pc111 ?
i have pipes with my o2 hooked up can i plug them or no need for o2 eliminators
Old Jul 29, 2007 | 12:18 PM
Mascman's Avatar
Mascman
Default RE: pc111 ?
ORIGINAL: 06 lowrider
Follow the wiring and you'll probably find that they are NOT hooked up...still installed in the pipes just to plug the holes.
Go to www.PowerCommander.com and you can download the instructions.
It would also be easier to read your posts if you used proper punctuation and capitalization.
Old Jul 29, 2007 | 12:19 PM
Mascman's Avatar
Mascman
Default RE: pc111 ?
You should also have a small connector to run a 9volt battery on the PCIII when you remove it from the bike and want to hook it up to your home comp.
Old Jul 29, 2007 | 04:19 PM
greg3131's Avatar
greg3131
Default RE: pc111 ?
make sure the o2 eliminators are disconnected. one gets disconnected bottom front of the bike frame. other gets disconnected under the seat. get your bike dyno-tuned.
learn to read and write better.
Greg 07 fxdb
[/align]
Old Jul 29, 2007 | 06:29 PM
06 lowrider
Default RE: pc111 ?
learn to read and write better. What the f*^(*&%($
Old Jul 29, 2007 | 06:53 PM
06 lowrider
Default RE: pc111 ?
well i guess my next question is, I went out and checked my bike and both o2 sensors are still hooked up. I followed the wires and they are still plugged in. So does that mean the shop has hooked it up wrong ? that was tough They proper typing. They need to get voice chat in here Thanks
Old Jul 29, 2007 | 07:07 PM
Mascman's Avatar
Mascman
Default RE: pc111 ?
Are you absolutely sure?
Did you follow them back to where they are plugged into the harness?
The O2 eliminators should be plugged into the harness on the computer side...basically fooling the computer into thinking the sensors are hooked up.
If the sensors are still plugged in, go back to the dealer and bitch!
Find out what map they loaded on and get the rest of your packaging from the PCIII...cords and all. Get a refund for the install too!
