Introduction
Old Nov 16, 2020 | 05:17 PM
Suede Blue Man's Avatar
Suede Blue Man
Welcome! Buzzing you say, a perfect excuse for bigger cams
Old Nov 16, 2020 | 06:10 PM
MBinGA's Avatar
MBinGA
4th Gear
Thanks all! Yes indeed TOE CUTTER, drained and flushed the brakes as well, thanks for the tip!
Old Nov 16, 2020 | 06:11 PM
MBinGA's Avatar
MBinGA
4th Gear
Sounds good!
Old Nov 16, 2020 | 06:15 PM
MBinGA's Avatar
MBinGA
4th Gear
Thanks nevil! Good idea, they may have to wait until Spring though. I do agree, they still have the new tires nubs on them, so they look fine but ... that may be misleading.
Old Nov 17, 2020 | 11:28 AM
OneGearhead's Avatar
OneGearhead
Congrats on the "barn find"!! Welcome to the forum, from VA.
Old Nov 17, 2020 | 01:51 PM
John CC's Avatar
John CC
I assume you're talking about the tires. Be advised, I had a 10 year old tire suffer a sidewall failure on the trailer ride back home. If it hadn't had a tube in it it would have been a blow-out.
Old Nov 19, 2020 | 08:37 PM
REW13's Avatar
REW13
Man don't go by the nubs, look at the side walls. If you see cracking replace.. Look in the tread grooves too.
But great Queen find...
Old Nov 20, 2020 | 11:35 AM
John CC's Avatar
John CC
Look at the date code. If it's over 3 years old it's suspect. More than 5, plan on replacing it. More than 10, stand back!
Old Nov 20, 2020 | 04:24 PM
MBinGA's Avatar
MBinGA
4th Gear
Thanks All for the feedback and highlighting the tire risks. On another note, I believe I solved my other problem: "It has a lot of buzzing at low to mid range RPM." Using the time proven "screwdriver as a stethoscope" while my Mrs held the throttle open, I could pinpoint the buzzing to the valve train. Withing two minutes of searching online I learned this is a very common design flaw in the rocker arm shaft bolt fit and is solved with "rocker lockers". Knowing what it is and how to fix it, makes all the difference. Thanks again.
LN2_Casey
Harley-Davidson Street
13
Jul 1, 2020 09:42 PM
Steve Kuzee
May 13, 2018 06:58 PM
GomerPyle
Aug 10, 2017 07:16 AM
hickory67
Exhaust System Topics
Aug 24, 2012 11:29 PM
Dr. Tiki
Feb 28, 2010 07:20 PM
