BCM and ECM replacement
Old Dec 30, 2020 | 08:19 PM
cyclecircus's Avatar
cyclecircus
5th Gear
Thanks for all the advice. Happy holidays
Old Dec 30, 2020 | 08:22 PM
cyclecircus
5th Gear
I am going to try jumping it at the starter to see if it will start but I thought the bcm also controlled power to the coil?? Thanks for the advice.
Old Dec 30, 2020 | 08:25 PM
cyclecircus
5th Gear
How does the vin gurus web site work? Will the list out the bcm P/N ? I am confused
Old Jan 9, 2021 | 12:01 AM
cyclecircus
5th Gear
Does anyone have a source for a new BCM, other than the local dealership?
Old Jan 9, 2021 | 04:48 AM
smitty901's Avatar
smitty901
Originally Posted by GearheadMike
I got the Centurion Super Pro HD, which does everything on the Harley, but you pay for a per bike license. It was $35.
It is also a full featured tuner, but again, you buy a per bike license for that as well.
Here are features. It did not paste well but you get the idea . . .
Main Features
Carburetor Tuning
Coolant Pump Testing
Data Logging & Data Analysis Digital Dash Monitoring ECU Read & Clear DTC Full Diagnostic Report
Key FOB Coding
Model Year Bike Schematic Web Link
Multiple Meter Monitoring Radio & Speaker Configuration
Recover Locked Security Modules (TSSM/HSFM/BCM)
Re-flash Blank ECU & Enter New VIN
Speedometer Calibration
Speedometer Pairing
Strip Chart Monitoring
(up to 16 channels simultaneously) System Information
Tuning Capabilites
VCM Data Logging
Active Tests ABS Pump Motor Activation
ACR Compression
Chassis Fan
Coils
Coolant Pump
Cooling Fan
Drive By Wire Throttle Actuator
Fuel Pump
IAC
Idle RPM
Injectors
Front Apply/Release Solenoid
Rear Apply/Release Solenoid
Speedometer
System Relay
Tachometer
Throttle Actuator
Throttle Grip
Active Settings ABS Front Purge
ABS Rear Purge
Adjust Idle RPM
BCM, TSM, TSSM, HFSM
module replace/marry to ECU
Disarming TSSM/HSFM/BCM
ECU Cloning of an Original ECU for a Blank ECU
Enable/Disable ACR
Enable/Disable Air Cleaner Valve
Enable/Disable Alarm
Enable/Disable Auxillary 1 & 2
Enable/Disable Chassis Fan
Enable/Disable Cruise Control
Enable/Disable EITMS
Enable/Disable Exhaust Valve
Enable/Disable Fork Lock
Enable/Disable Instrument TPMS
Enable/Disable Keyless Ignition Mode
Enable/Disable Lights Configuration (BCM)
Enable/Disable Oil Fan
Enable/Disable Power Lock
Enable/Disable Service Mode
Enable/Disable Side Car
Enable/Disable Side Stand
Enable/Disable SMS Text Messaging
Enable/Disable TPMS
ECU Read & Clear DTC Radio, ABS, TSSM/HSFM/BCM, Speedometer Read & Clear DTC Fuel Tank Draingage
Key FOB Coding
Reset Air Fuel Valve
TPMS Manual Sensor Coding
TPMS Replacement
Radio Zoning DOM (Domestic)
Radio Configuration Amp 1 & 2
Aux 1 & 2
BlueTooth
CB
Intercom & More…
Speaker Configuration Speakers w/o boom amp &
enhanced equalizer
Speakers w/ boom amp &
standard equalizer
BCM Configuration ABS Installed
Fog
Head Light
Radio Installed
Service Mode
Side Car
Stop Light
SwitchLess Key & More…
Indicator Lights 6th Gear
ABS Service
Alarm
Battery
Check Engine
Coolant Temperature
Cruise Control
High Beam
Low Fuel
Neutral
Oil
Security
Left & Right Turn Signal
All features vary by bike model
I have one function I need to disable or enable (2020 Harley) and that is the BAS for sidecar. Is there something a bit less over the top than this that can do that ?
Old Jan 15, 2021 | 03:16 PM
jeb42's Avatar
jeb42
Yes he had to take it to Harley to make the code go away.
Old Apr 11, 2024 | 12:45 AM
llbmotors's Avatar
llbmotors
Stage II
Default Hey I just did the Same this no key no fob no code 2016 if I get this it will do the trick?!
How were they damaged in a wreck? I bought a wrecked bike, no key, no fob, no code, and was told by everyone I needed to replace the BCM. I ended up purchasing a TechnoResearch unit for $400 and it fixed the BCM, fixed the security problem, programmed a key fob, and married a new speedo to the ECM. It does as much or more then the dealers digital tech.
https://technoresearch.info/
I just did the same thing you did I have no key no fob and no security code on 2016 road glide seems like all I need to do is buy this techno research and I can flash everything myself?!
Old Apr 11, 2024 | 05:54 AM
smitty901's Avatar
smitty901
They are no longer selling the payper bike version . You just need to take it to a shop that has the centurion pro.
Old Apr 11, 2024 | 05:58 AM
smitty901's Avatar
smitty901
delete
Old Apr 11, 2024 | 08:57 AM
llbmotors's Avatar
llbmotors
Stage II
Default Ok darn
wouod I be able to just get a new harness with the bcm and ecu or I would need that speedo as well to since everything I basically got everything torn down and I’m gonna be building it all back up on a new frame that I’m gonna try doing a custom build
Big Twi$t
May 3, 2024 05:49 AM
QStar42
Jun 5, 2017 10:09 PM
UHDhog
Aug 21, 2016 03:05 PM
YoDA
May 15, 2009 08:03 PM
flyboy44
Dec 28, 2005 11:40 AM
