2005 Lowrider Handlebars
Old Aug 1, 2007 | 11:41 AM
2006RKCI's Avatar
2006RKCI
5th Gear
Default 2005 Lowrider Handlebars
I think most of us have this problem...I am 5'8" and the stock handlebars on my 2005 Lowrider set too far forward. I would like replace them with reduced reach type handlebars - minimal wiring problems...any suggestions? Thanks.
Old Aug 1, 2007 | 11:49 AM
bikerdog134's Avatar
bikerdog134
Default RE: 2005 Lowrider Handlebars
have you considered a different seat
Old Aug 1, 2007 | 11:56 AM
2006RKCI's Avatar
2006RKCI
5th Gear
It's the same with stock seat, Sundowner Deep Bucket and my Corbin Hollywood Solo...I had the same problem with my'06Road King Classic but Harley makes a reduce reach handlebars (I purchased and installed) and solved the problem. I haven't seen a Harley replacement...
Old Aug 1, 2007 | 11:58 AM
2006RKCI's Avatar
2006RKCI
5th Gear
I haven't seen a reduce reach handlebars replacement for the Lowrider...maybe aftermarket?
Old Aug 1, 2007 | 11:59 AM
icecaps's Avatar
icecaps
Reading More Posting Less
Harley makes a reduced reach bar for the Deuce. Not sure about fit but it's only $49.
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Old Aug 1, 2007 | 12:01 PM
2006RKCI's Avatar
2006RKCI
5th Gear
Thanks, I'll call my local HD Dealership and check it out.
Old Aug 1, 2007 | 01:56 PM
Trout's Avatar
Trout
I installed bars off a 2001 Superglide on my 2005 Low Rider. Cables and wiring reach. The bars are about an inch higher and about 2 inches further back. Nice.
Old Aug 1, 2007 | 03:14 PM
2006RKCI's Avatar
2006RKCI
5th Gear
I'll check this out...the bars from Duece won't work, according to HD. Thanks!
Old Aug 1, 2007 | 07:51 PM
murphdog's Avatar
murphdog
If you're looking at the 56330-00 Deuce bars, they'll work fine. I had a set on my 03 Wide Glide with the same pull back risers that are on a Low Rider. Your dealer is just telling you they won't work because the catalog only lists them for 00-07 FXSTD.The 56154-04 Softail Standard bars will come back quite a bit further than your stock bars as well. The Standard bars are a little narrower than the Deuce bars, butboth are similar as far as height and pullback.
The dimensions for the Deuce bars on Harleys website and cataloghave beenwrong for the past few years. From an old catalog, they are 31" wide, 10" base width, 5" rise and 9" pullback.
Old Aug 2, 2007 | 01:21 PM
2006RKCI's Avatar
2006RKCI
5th Gear
Thanks, I'll check them out.
ohfivefxdxi
May 21, 2013 09:12 AM
john182
May 30, 2007 07:21 AM
john182
May 24, 2007 10:46 PM
Custom07RKC
Dec 25, 2006 12:33 AM
Manish_Hawg
Mar 22, 2006 01:52 PM
