Inner Primary Bearing
Old Aug 19, 2007 | 09:41 AM
  #41
fastfxrs's Avatar
fastfxrs
Default RE: Inner Primary Bearing
[quote]ORIGINAL: Black Bart
Juan,
Is this noise hearable with loud pipes. What are the symptoms?
Bart, I can hear mine with earplugs and a helmet, over my Khrome Works slip-on pipes. I'm pissed. Getting the run around at my dealer too. What a joke. Buell would have been all over this problem, kissing peoples a$$'s to get in fixed. I have a '07 WG with what the service manager at the dealership calls "normal noise, they all sound like that."
Old Aug 19, 2007 | 09:45 AM
  #42
Psycho's Avatar
Psycho
ORIGINAL: Franklin
Yesterday morning, when I checked the can I'd left underneath...there was very little fluid...not even enough to gather to one side when tilted. Anyway, I wiped everything clean, started it...and laid down to look for the leak. I only let it run for about five minutes (on the kickstand). I didn't see anything leaking, although I knew damn well that it hadn't fixed itself (it leaves a small puddle at red lights). I turned it off and still no leakage around the drain plug or primary gasket. But then...I saw it...running down what I guess is the inside cover...and collecting at the drain plug. I don't have the service manual yet, so I don't really know what it looks like in there, but the oil is running down in the area just above the drain plug. I rode it about ten miles before I noticed the severity of the problem, and the only way I can get it back to the shop (six miles) is to ride it. Now I wonder about the level of fluid left? Also...does that sound like something that they can fix quickly, like while I wait?
Sound like the seal behind the primary bearing on the backside of the primary housing is leaking, or missing altogether.
No, that's not something they can fix quickly while you wait. Will have to be torn completely down again, primary chain, compensator, and clutch removed, inner primary case removed, bearing race inspected for damage, (seal rides on back of inner bearing race), and new seal pressed into inner primary case.
Old Aug 19, 2007 | 10:56 AM
  #43
Franklin's Avatar
Franklin
Wow...what a pain in the ****
ORIGINAL: Psycho
ORIGINAL: Franklin
Old Aug 20, 2007 | 11:43 PM
  #44
nkauf21's Avatar
nkauf21
At 10,000 miles my bearing seems to be ok. No weird sounds or anything like that. My question is for you guys that have had it replaced, what did it cost. Was it warranty work for some of you. My warranty is up in a month, but when i hit 15,000 i will need to replace it. I may wait on forward controls and let them install those when they have it all apart.
Old Aug 21, 2007 | 12:35 AM
  #45
WildBill76's Avatar
WildBill76
I typed in my motorcycle Vin number and milage. The Harley servive site still says to replace the bearing every 15,000 miles.
Old Sep 13, 2007 | 02:28 PM
  #46
Davesurf's Avatar
Davesurf
My inner primary bearing went out, I got 24,500 miles on my 06 Street Bob, bike is at the dealer now getting fixed under warranty, no hassle's about warranty either.
Old Nov 24, 2007 | 03:58 PM
  #47
Leesiple's Avatar
Leesiple
What aftermarket options are out there for replacing/upgrading the bearings?
Old Nov 24, 2007 | 04:40 PM
  #48
DougsDyna's Avatar
DougsDyna
I notice that after the engine is good and hot that I get a new noise now when I put the bike in neutral and let the clutchout. It's just a noise but not something that is causing me concern at this point.
I would highly recommend taking it to the dealer to get that particular "noise" documented. I don't want to alarm you or anybody else, but that noise is indicative of the primary bearing starting to fail.
If it turns out to be "nothing", at least you can feel secure knowing the dealer has had a service order opened on it.
I got dicked around on this issue, and by 18,500 miles there was no bearing problem, because it and the race were completely gone along with the the dogs and sliders. My "noise" started around 2500 miles, and would kinda come and go.
Keep a close check on your tranny oil.......... If you oil begins to show a lot of silver (color in oil) you have a big problem. When the oil turns gold in color, that is the race................ Ask me how I know
My 06 FXDI was one of those early production models, and seemed to have a number of those "normal" Harley noises. If your buds start asking you "Hey, what's that funny noise?" when you are in nuetral, there is a good chance your bearing is going bad.
Hope this helped in some way................. BTW, my tranny is so quiet now, all I hear now is the roar of the pipes and wind through the hole in my head.
Good Luck
DougJ
watindes
EVO
Aug 30, 2013 06:52 PM
lowrider6
Jun 26, 2013 08:47 AM
jpooch00
EVO
Mar 19, 2012 05:46 AM
epsmith
Jul 31, 2011 12:04 PM
Krash26
Jun 19, 2011 10:53 AM
