Oil pressure too high?
Old Apr 3, 2021 | 08:51 PM
Shadowjag's Avatar
Shadowjag
Yes on the alignment. Did it by turning the wheel as I tightened the bolts. It "Should" be ok. 🤞
Still using stock rods and slowly tightened the rocker assembly as the lifters bled.
Old Apr 3, 2021 | 09:12 PM
QC's Avatar
QC
Ok. Then trust your work and ride it a bit.
I was cautious my first time in there too.
Old Apr 4, 2021 | 06:51 PM
Shadowjag's Avatar
Shadowjag
Back together and let it run for a few. Waiting on an HD oil pressure gauge being shipped.
In the meantime I found the shift lever has come loose behind the primary.
Does it ever end? 🤪
Old Apr 28, 2021 | 09:06 AM
Shadowjag's Avatar
Shadowjag
Put the new HD oil pressure gauge in and it's reading 20 -30 psi at idle when warm. It shoots up to 60+ when I give it throttle. Ideas? Lifters? Can a badly seated oil pump really cause that increase and only the increase symptom?
Old Apr 30, 2021 | 12:04 PM
QC's Avatar
QC
That is the same as mine. Been running like that for 9 years now.
Old May 2, 2021 | 08:26 AM
Shadowjag's Avatar
Shadowjag
I actually read it this time after a good ride. 10-12 at idle and 30-40 when revved. Sewing machine tick and the initial high reading was making me nervous. 😓...Much better now 😃.
Old May 2, 2021 | 08:30 AM
QC's Avatar
QC
Thanks for the update!
Ride safe!
IronHead1959
Nov 19, 2020 04:38 PM
Streetrunner
Apr 15, 2013 10:38 PM
mteed23
Mar 18, 2011 08:48 PM
jseabee
Oil Archive (no new posts)
Jan 7, 2008 06:13 PM
jjb
Exhaust System Topics
Nov 21, 2006 05:02 PM
