570 Cam Base Circle?
Old Apr 16, 2021 | 02:00 PM
fordhd2005's Avatar
fordhd2005
Originally Posted by fxdx1985
Running Screamin Eagle adjustable taper pushrods. Instructions say 2 1/2 turns but I opted for 3. Not sure if I should go more or less honestly....
Def could be rocker covers due to new springs. This is snowballing pretty big here haha.
I would have to assume those instructions are based on using stock HD lifters. Are you using stock lifters? If not, which ones? If the rocker covers are the issue, you should be able to see witness marks when you pop them off.
Old Apr 16, 2021 | 02:04 PM
fxdx1985's Avatar
fxdx1985
Yeah I hear ya. I know what needs to be done, I just don’t wanna haha. I was patting myself on the back because I was super careful, followed instructions to a T and still ended up with a headache. I wanted that easy bolt on power but here I am chasing gremlins.
Old Apr 17, 2021 | 11:39 AM
ROCKOUT Rocker Products
Sponsor
I don't know the base circle for that cam but they are not all the same, far from it.
It's not uncommon to have to ride 5 miles or so to get the lifters fully pumped up & everything sorted. It's a little tense for sure.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Apr 18, 2021 | 01:40 PM
misfitJason's Avatar
misfitJason
Being as you had your heads decked....it's either your lifters aren't pumped up still, or the pushrods are contacting the tubes somewhere.
I have decked heads and I have andrews 37h cams. I have a clicking noise all the time like you. It's just my specific setup that makes them noisy. I chased everything and it is just a fact of life that it is noisy.
Old Apr 19, 2021 | 12:44 PM
fxdx1985's Avatar
fxdx1985
I think a stock lifter took a **** though I couldn’t visually see anything upon inspection.
I dropped S&S premiums in there and the clanking is gone, just the normal “sewing machine” chatter from gear drive cams.
Thanks for the feedback fellas 👍🏻 Just need to start throwing down some break-in miles and get a tune and we’re golden!
Old Apr 19, 2021 | 07:46 PM
60Gunner's Avatar
60Gunner
Not all cams use the stock size base circle. It's not uncommon at all to use a smaller base circle as a means to get more lift. I ran cams in my Sporty that had smaller base circles.
The 570s however do use the same.
Make sure the cylinder you're adjusting is on tdc compression, not overlap.
That said, using solids is not a bad idea if you really want. Eliminates some potential issues that can and do happen occasionally with adjustables. But I would have some custom made to put slightly more preload on than the stock .100 I think it is. Like adjust the adjustables since you have them then measure them.
I know most would say this would be a waste of $$$ and not necessary but I know people including builders that would never use adjustables and I'm not fond of them myself even tho I'm using them atm.
I've considered doing this next time I pull my heads.
kllrvet
Milwaukee Eight (M8)
Jul 2, 2017 07:19 PM
Stopit
Engine Mechanical Topics
13
Feb 17, 2014 09:20 PM
Stl.glider
Jan 4, 2013 08:45 AM
SmittyFXDL
Mar 19, 2012 06:54 PM
dirtpan
Exhaust System Topics
Oct 31, 2007 11:27 AM
