Performance Fork Rebuild
Old Mar 8, 2022 | 03:18 PM
  #41
GearheadMike's Avatar
GearheadMike
You need to talk to Race Tech. I would not trust TrackerDie in this situation. The point of drilling the stock damper rod is to reduce it's negative effect, and let the new valve have it's control.
One note: Don't confuse 'preload' with spring rate.
The spring is manufactured to a specific spring rate, and chosen for the weight of the bike and rider.
The 'preload' is for adjusting sag or ride height. When you are sitting on the bike, you want the 'sag' ( suspension compression ) to be in the top third of your total suspension travel. Simply put, if you have three inches of total travel, you want it to 'sag' one inch, with weight on it. You would add preload to your rear shocks for a passenger, to bring the ride height back up to one-third, to compensate for additional weight. The spring rate is still the same.
Old Mar 8, 2022 | 03:53 PM
  #42
John CC's Avatar
John CC
Race Tech calls for holes totaling 0.46 sq. in. The TrackerDie holes add up to 0.2 Square inches. I'd drill the four holes out to 5/16" and add two more similar to the drawing from Race Tech.
You could try contacting TrackerDie and telling them what you're trying to do. They might give you a recommended placement for the additional holes.
Old Mar 8, 2022 | 03:54 PM
  #43
snake_eyes's Avatar
snake_eyes
I spoke to RT and here's what they said.
The 4, 1/4" holes should be fine and he guessed that's maybe what TrackerDie found worked best for their setups. But since I can't confirm with TrackerDie he suggested drilling the 4 holes out to 5/16 and I'd be good-to-go. That's what I'm going to do and start putting things back together.
Old Mar 8, 2022 | 04:06 PM
  #44
John CC's Avatar
John CC
That'll get you up to 0.31 sq. in.
Old Mar 8, 2022 | 04:17 PM
  #45
Max Headflow's Avatar
Max Headflow
Can you measure the ID of the fork tube where the damper slides?
Old Mar 9, 2022 | 07:02 AM
  #46
multihdrdr's Avatar
multihdrdr
Do you want the Tube ID or the Check Valve ID?
Old Mar 9, 2022 | 08:15 AM
  #47
snake_eyes's Avatar
snake_eyes
So, funny story.
My original question was if anyone had specific experience with the TrackerDie +2 damper tubes that are sold as "pre-drilled". Well, we all fell down a rabbit hole of math and conjecture, and don't get me wrong I learned a thing or 3 from you guys but after all that discussion and phone calls, and measuring and taking pictures and not working like I should be, I finally got ahold of TrackerDie. Their crew was out at the Mama Tried show so they have a skeleton crew working. Anyhow, it turns out, wait of it...they sent me the wrong damper tubes for my order, they are not pre-drilled. They're going to get the order sorted out and send me the correct part, which has 6, 5/16" holes in it.
Old Mar 9, 2022 | 08:18 AM
  #48
John CC's Avatar
John CC
Old Mar 9, 2022 | 08:31 AM
  #49
multihdrdr's Avatar
multihdrdr
Btw, "Conjecture" would not be the best word to use for some of us
Old Mar 9, 2022 | 08:33 AM
  #50
snake_eyes's Avatar
snake_eyes
Present company excepted of course
