Just back from the dyno...
Old Aug 10, 2007 | 06:04 PM
jonesc937's Avatar
jonesc937
Default Just back from the dyno...
Anybody remember off hand what the stock HP and torque numbers are on the 06s. I just got back from the shop and ended up with 72hp and 75.5 torque with Shortshots and an SE AC. I'm pretty satisfied vs. the numbers I had with the first map I had for this set up. The guys also got rid of 99+% of the decel pop. I know that you get better performance from other pipes but, all and all, okay ....for now.
Old Aug 10, 2007 | 06:10 PM
Lildude11d's Avatar
Lildude11d
Default RE: Just back from the dyno...
What did you go aftermarket fuel mangement system?
If so what did you use?
Old Aug 10, 2007 | 06:16 PM
jonesc937's Avatar
jonesc937
Yeah, PCiii. Forgot to mention that before.
Old Aug 10, 2007 | 06:19 PM
Lildude11d's Avatar
Lildude11d
Kool, I have been looking at that one and the Thundermax but Got to wait alitlle bit maybe after the season I'll get some pipes and a mangement system.
Old Aug 10, 2007 | 06:29 PM
Arcane's Avatar
Arcane
Your torque and horse power numbers are correct for the modifications that you have. Obviously some will show lower and some will show higher, but yours are certainly in the, “hey that’s good range.”
Arcane
Old Aug 10, 2007 | 07:39 PM
jonesc937's Avatar
jonesc937
Thanks.Its good to hear that from someone. I've spent hours searching the forums reading about these pipes. Based on what others have said, I didn't expect anything amazing but, for the price of the pipes (combined w/the looks and sound) I didn't think it turned out to bad. I'm planning (read : saving up) for a 95" kit after the first of the year. Then I'll be looking for some much better numbers. No matter what the print out says, the bike runs great and doesn't pop any more. Glad I did it, without reading some of the great posts here on the subject, I might not have.
Old Aug 10, 2007 | 08:11 PM
6165hd's Avatar
6165hd
stock 06... 88 TC, my read out was 58.24 hp and 66.24 max torque....Your right on the money with your dyno tune,,, I avg, in the 70"S ...with stage I and reinharts.
With the 95TC upgrade,, be sure to ask about redoing the heads as well.... my dealer was suggesting them as well.. you should ask them about it when you do the whole deal to be sure your happy with the end result for the $$$ spent... also the Cams.
Old Aug 10, 2007 | 09:01 PM
Cabo's Avatar
Cabo
Your numbers are right on.
Old Aug 11, 2007 | 03:06 PM
jonesc937's Avatar
jonesc937
You all are making me feel better and better. I had no idea that the stock numbers were that low. I remember reading them somewere but didn't have time to go out and look it up. I thought they were a bit higher. I was getting 66hp and 71 tq before w/ a Fuel Moto map. Glad to see I'm in line w/ were I should be.
Old Aug 11, 2007 | 09:18 PM
mentor70's Avatar
mentor70
My stock 05 dyna with the 88 in did 62 hp and 72 lbs of torque with short shots and a Mikuni 42.
I was a little bummed, thats what it should be doing stock.
I chucked those short shots for a Thunder header, man what a difference!
I havent dynoed my 95 incher yet, but the butt dyno is saying 100 lbs of torque!
