07 dyna primary oil leak
Old Jan 24, 2022 | 12:48 AM
BF-Demo's Avatar
BF-Demo
Default 07 dyna primary oil leak
I have a reoccurring oil leak from the inner primary on my 07 Dyna with the 96 motor and the 6 speed trans. it looks like it comes out of the inner primary seal, but something else is causing this. this is the 3rd time it has come up in about 8k. I have replaced the seal twice and the bushing once. after I replace the seal there is no more leak until I go for a ride >500 miles. this thing leaks while running and while parked, just sitting there while I was out of town for 2 weeks it leaked out a puddle about 12 inches wide if not more. I do regular fluid changes and had a mechanic change the seals and bushing. so the question here is what is causing the bike to leak now all of a sudden. it ran for 50k before this happened and now a can't seem to get it to stop.
the bike: 07 dyna street bob with fueling 543 cams, big sucker intake, V&H short shots (I need a 2 into 1 I know $$$), dynojet tuner.
Old Jan 24, 2022 | 01:49 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Welcome from North Beach, FL., USA!
Just in case you have not done both of these two important items!
Be sure to add an Avatar of your favorite shot in the USER set up for the small picture others will see in the top left corner of your post with your USER name.
And most importantly a Signature Line in your USER set up for your bike model, year, and all the letters that Harley recognizes it with that others see at the bottom.
This enables others to know your exact model if you ever ask a question or another member interested in it may ask you a question about it.
​​Your all set.... Enjoy the ride! ______________
Old Jan 24, 2022 | 02:29 AM
critter85's Avatar
critter85
Welcome to the Forum lots of good information here
Old Jan 24, 2022 | 06:53 AM
Spartanden's Avatar
Spartanden
Good Luck!!
Old Jan 24, 2022 | 10:57 AM
470004's Avatar
470004
Welcome from New York.
Old Jan 24, 2022 | 12:02 PM
BF-Demo's Avatar
BF-Demo
Old Jan 24, 2022 | 12:12 PM
diablos's Avatar
diablos
my only thought would be to put some die in there to track down where its leaking from
Old Jan 24, 2022 | 01:14 PM
Bob_fxdb's Avatar
Bob_fxdb
Check seams and cracks.
I don’t understand how it would leak on the inner when the bike is on the stand leaning to the left. It’s should not be enough fluid to do that. Sure it’s primary oil? Maybe transmission or engine oil? Check oil pan. Anyways, it should be easy to trace the leak
Old Jan 24, 2022 | 02:25 PM
WVHARLEEMANN's Avatar
WVHARLEEMANN
Hello and welcome to the HD Forums from West Virginia (USA). Glad you have joined us all here.
Old Jan 24, 2022 | 03:43 PM
BF-Demo's Avatar
BF-Demo
thats a good idea, I will have to find some dye and see what I find out. thanks
