What is the purpose of this triple tree screw?
They are correct that one never wants a ground thru a bearing
However, I did think first poster saying the big eye was no longer attached to anything. And I assumed it had once been a ground for passing lamps or something that had been removed.
That wire I did not believe it to be the ground for the trees to the frame neck. It's not long enough nor have I ever saw a Harley with the ground there.
However, not saying there not.
So when Dan went on attack mode, answer came out were eye went. Interesting since I have a tac up high above the risers for tac but it also has a ground wire. My Softail doesn't have riser bushings either however and would not need a bridge ground wire.
My confusion was I thought the problem was just hooking the little eye to a new tree.
It only took them 93 years to figure it wasn't a reliable path for ground.
That wire is the ground path to the bars for the front turn/run on the bars as the riser bushings insulate the bars from the trees.
If OP's bolt is hitting the riser bolt it's too long.
