Cv40 carb
Old May 23, 2022 | 09:37 AM
Dukes37's Avatar
Dukes37
6th Gear
Originally Posted by crzoomb
Factory air box or aftermarket ? you may be lean when transitioning from the pilot jet to the needle jet.
I have 40mm CV carbs on my GSXR 11100 , the pilot jets are tiny and would always get partially plugged.
Have to pop off the float bowl to access the pilot jet.
Probably best to pull, pilot, needle, emulsion tube, and main jets.Document the sizes, there will be numbers or letters stamped on them.
Is the petcock vacuum operated ?
petcock is vacuum operated and factory airbox but I went to an off brand filter that looks like a k and n filter
Old May 23, 2022 | 10:02 AM
SirHarley's Avatar
SirHarley
Cool
Sounds like you have a dirty carb or air leak somewhere like in the intake seals. You don't have a choke, because it's really an enrichened circuit on your carb. You don't have a butterfly either, since you have a slide. Since it ran while the enrichener was on, that tells us that something is clogged or leaning out the engine. There are small fuel circuits involved here besides main and small jets. The petcock is also a potential source of trouble. Remove it entirely, and look at the filter screen. You're going to have to work to eliminate all of these issues as they may exist. Did you find any crud, gel, or build up in your carb the first time? The entire system (Tank, Petcock, and Carb) may need to be cleaned and flushed out. Check your vacuum hose to the petcock. That may be leaking as well.
Remove, disassemble, and thoroughly clean the carb within an inch of its life. put the disassembled carb in an ultrasonic cleaner if at all possible. If you remove the idle and mixture screws document where they were at first, or you will have to dial them in later. it's good to document the jets as suggested as well. Don't make any shortcuts or hurry through the cleaning, or you may wind up back at square one.
Also, I wonder how good of a shape the intake seals are in? It may be time to replace those while the carb is off. They can wreak havoc on a carb and cause a lean condition. The intake seals are notorious for failing btw. If you have gotten more than 5 years out of them, then you are on borrowed time already...
Old May 23, 2022 | 11:16 AM
Max Headflow's Avatar
Max Headflow
Main jet plugged.
Old May 23, 2022 | 11:45 AM
Dukes37's Avatar
Dukes37
6th Gear
thank you for the detailed suggestions I will definitely try all of this
Old May 23, 2022 | 12:46 PM
Professor Fate's Avatar
Professor Fate
And remember that you ALWAYS have to pull the petcock right after you fill the tank with gas. Or at least it seems that way.
Old May 25, 2022 | 09:56 AM
Yankee Dog's Avatar
Yankee Dog
Make sure your needle jet is installed and installed correctly. It is an easily lost item especially if not familiar with the carb. When I say needle jet, I do not mean Main Jet. They are two separate things.
Also the holes in the emulsion tube and in the slow jet are very small. Take a good look at those items.
Hold your diaphragm up to the light to look for holes.
For giggles, replace your intake manifold seals and your carb to intake manifold seal. The carb to manifold seal is suspect if old and if you have removed and replace the carb multiple times.
The intake seals just get old. Replace them.
Old May 25, 2022 | 01:20 PM
Professor Fate
I had a similar problem on a CV carb I rebuilt. Missed installing the needle jet as I was putting it together. Ran the same way yours did until I found the problem. You can see the top of the needle jet on the bottom of the venturi where the needle from the diaphragm enters. Make sure it's there and the correct right side is up (refer to a carb diagram if you need to).
lowflyer
Carburetor Related
Aug 18, 2014 08:20 PM
ryamatt
Jul 7, 2013 08:14 PM
som69
EVO
May 30, 2013 07:47 AM
purple99sporty
Jul 21, 2012 04:04 PM
bubba_d_duck
May 5, 2007 12:27 PM
