Could use some help?????
Old Aug 14, 2007 | 08:50 PM
grueter's Avatar
grueter
Default Could use some help?????
Looking for some help. 06 Wide Glide V/H Big Radius,Big SuckerAC and PCIII. Bad Vibration when I put on front. or rear brake at 20 to 30 mph decell any gear.It can also be felt at idle by just steping on the brake pedel or pulling the front brake leaver not moving standing still. Never had this problem before the stage 1.Any Idea?
Old Aug 14, 2007 | 08:55 PM
Trotter's Avatar
Trotter
Default RE: Could use some help?????
Brakelight switch's sending false codes to the pcIII or ECM ? Aftermarket plug wires will do the same thing.. Most dont realize it...
Old Aug 14, 2007 | 09:17 PM
grueter's Avatar
grueter
Is there any way to check the brake light switch with the PCIII? Also for got to tell everyone only have 4,000 miles on my bike.
Old Aug 14, 2007 | 09:24 PM
Trotter's Avatar
Trotter
Unhook the pcIII and see if it stillhappens...I've seen the screaming eagle wires send all kinds of false codes, any kind of bad connectionswill pick up the signal and cause problems even to the Stock ECM
Old Aug 15, 2007 | 09:05 PM
grueter's Avatar
grueter
Question If I unhook the PCIII and rehook up the HD unit is there anything that I will lose (map or anything).Do I need to hook up my O2 sensorjust to check this problem out. Thanks again.
Old Aug 15, 2007 | 09:11 PM
Splatter's Avatar
Splatter
You might also check/retorque your engine mount bolts.
Old Aug 15, 2007 | 10:44 PM
Trotter's Avatar
Trotter
Not to check it out... The ecm will be as you left it
Old Aug 15, 2007 | 11:11 PM
mud's Avatar
mud
ORIGINAL: grueter
Any Idea?
Either I'm reading this wrong, or somethin stinks here.
Let me see if I understand you -
When you are sitting still,
You step on the rear brake,
or, depress the front brake lever,
you feel a vibration.
Is that what you are saying here??
mud
Old Aug 16, 2007 | 06:15 AM
grueter's Avatar
grueter
Yea Mud Standing still Frt.or Rear brake applied the bike Vibrates more than normal. Increase RPM standing still the bike shakes BAD.Any Idea. Thank Ray
giangofett
Sep 24, 2017 09:07 PM
Scott Robbins
Engine Mechanical Topics
Dec 24, 2015 07:45 PM
LX Kid
11
Feb 13, 2013 07:13 AM
zworld
Jan 22, 2012 01:28 PM
stro1965
Sep 3, 2010 01:54 PM
