Help!!!! Crank no start 03dyna super glide
Old Oct 21, 2022 | 03:16 AM
Thumper73150's Avatar
Thumper73150
Stage II
Default Help!!!! Crank no start 03dyna super glide
Okay so I just bought this dyna and I have no spark. Change crank position sensor and ignition coil.
Old Oct 21, 2022 | 03:27 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Be sure you have at least one plug in to check. Really should just check for fire with a new plug grounded to engine. These system normal won't fire without cylinder compression on plug.
Make your next new post over in the new member area.
Just in case..
Welcome from North Beach, FL., USA!
Just in case you have not done this and I recommend this only as a suggestion....
Add a Signature Line in your USER set up for your bike year, model, and all the letters that Harley recognizes it with.
Others will see it at the bottom which
enables them to know your exact model if you ever ask a question.
All Harleys are not the same and year and all the model letters make a big difference.
Also, add an Avatar of your favorite shot in the USER setup for the small picture others will see in the top left corner of your post.
It's also very helpful to read the 'HDF Site Rules' listed at the top of the new member area.
https://www.hdforums.com/forum/welcome-area-only-4/
​​You're all set.... Enjoy the ride.
Old Oct 21, 2022 | 07:25 AM
TexasScooterTrash's Avatar
TexasScooterTrash
Run a diagnostic scan for ERROR CODES before ya start guessing and throwing random parts at it. OOPS, too late.
Old Oct 21, 2022 | 11:33 AM
nevil's Avatar
nevil
Was it running when you bought it? And if so, what was done to the bike since then?
Before you go buying parts that you haven't determined are bad, charge up the battery and get it load tested. With any electrical problem you should start with the battery.
Old Oct 21, 2022 | 10:25 PM
Thumper73150
Stage II
No it wasn't running when I bought it and already did the basic stuff like charge the battery and replaced the coil when I got a 1.5 ohm test out of both sides of the coil
KellyLeeMac
EVO
Jun 9, 2021 05:39 AM
jscratchy1@verizon.net
Oct 24, 2017 04:17 AM
scabmachine
EVO
May 20, 2013 07:35 PM
RenoHD-Rider
Aug 21, 2011 10:40 AM
Proudtexan
Dec 29, 2010 05:51 PM
