Kick start and magneto swap
Old Oct 28, 2022 | 10:46 AM
Luke321's Avatar
Luke321
Stage IV
Default Kick start and magneto swap
I am considering dosing a magneto and kick start swap on my 01 twin cam 88ci I looking for some advice on the topic I wanna remove the electric start and battery from the bike
Old Oct 28, 2022 | 07:44 PM
TOE_CUTTER's Avatar
TOE_CUTTER
Have you found the parts to do the conversion? After securing the parts, I would recommend compression releases and keeping the compression low. I have a friend who has a high compression shovelhead with dual releases, and there was a couple of times it kicked back and jacked him up.
Dave
Old Oct 28, 2022 | 07:55 PM
Luke321's Avatar
Luke321
Stage IV
Dave
yes I looked the parts up on JP cycle and found what I was looking for but I was curious if the lights would still work the same with out the battery our if anyone knew away around it
thanks
Old Oct 28, 2022 | 08:58 PM
TOE_CUTTER's Avatar
TOE_CUTTER
Here you go:
https://www.huntmagnetos.com/battery-eliminator/
I would set up an off/on switch for your headlight. Your headlight will work fine when the bike is running. Works good also for “late night runs”.
Dave
Old Oct 28, 2022 | 09:06 PM
Luke321's Avatar
Luke321
Stage IV
Here you go:
Dave
So this would work in link the the mag correct and thank u for all ur help and advice
Old Oct 28, 2022 | 09:28 PM
TOE_CUTTER's Avatar
TOE_CUTTER
Dave
Old Oct 29, 2022 | 07:44 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Just curious, why would you want to go this route?
Not judging, it’s your bike and you can do whatever you want. I get the cool factor but it’s not very practical.
Old Oct 29, 2022 | 08:22 AM
TexasScooterTrash's Avatar
TexasScooterTrash
Don't hack it up. IF ya really just gotta have a magneto, battery less, kick start Harley . . . get a 1966 Sportster XLCH.
Old Oct 29, 2022 | 09:19 AM
John CC's Avatar
John CC
I realize I'm a bit on the old side, but if I never have to kick a bike again (except for the T150 and Thunderbolt) it won't upset me a bit. When the grid didn't crash on 1/1/2000 I moved on...
Old Oct 29, 2022 | 10:33 AM
FX WideGlide's Avatar
FX WideGlide
I think it would be very difficult to get a late model Harley Twin Cam to start with a kick starter. EFI requires a higher cranking speed to get things to work. It might work with a magneto, but I'm trying to think where a magneto could be driven on a Twin cam.
When I rode flat track, my old Harley WR had the magneto mounted on the front of the engine where the generator went on a Generator Shovelhead, Pan or Kuncklehead. On a 45, you could also drop a magneto into the dristributor drive on the right side of the engine.
I'm not trying to be critical, since I understand that people do like to individualize their machines.
Good luck on your mods!
