90° Valve Stem
Old Nov 4, 2022 | 04:19 PM
M Oclaf's Avatar
M Oclaf
Originally Posted by snake_eyes
Okay, I saw this thread earlier, but I just re-read all five pages (I don't want to work today) and I see a couple of negative comments about the angled extensions, which is not what I am talking about and one lone comment about a failure on an angled stem that the guy admitted were cheap crap. Every other post was either glowing praise or "damn, I need one". The consensus seemed to be that the Bridgeport 83° stems from KurveyGirl were the best option. Am I missing something?
that dude is a Karen…you even proved it. lol 😂
Old Nov 7, 2022 | 11:58 AM
snake_eyes's Avatar
snake_eyes
Just so I can answer this thread in case someone else looks one day, I ended up ordering from kurveygirl.com. I called them because I could not find any information on the size I need for my FXDL rims. They were super nice and informative. For reference, my cast, 5 spokes are an 8.3mm stem. I ordered these beauties 83deg Aluminum 8.3mm Racing Angled Valve Stems - Black (2 pcs) - Gen2 – KurveyGirl
Old Nov 7, 2022 | 12:22 PM
sherob's Avatar
sherob
I've had them on 3 of my last bikes, over 150k miles on them, not one problem. Just make sure you have them pointing out to the high side.
Old Feb 20, 2023 | 02:24 PM
snake_eyes's Avatar
snake_eyes
I thought I'd post pics since I finally got the KurveyGirl stems installed on the new rims. They are VERY well made, installed solid as a rock and as you can see, there is no way that they are going to "fail" or cause interference. They are solid aluminum bottom to top and are going to make pressure checks a lot easier.
Old Feb 22, 2023 | 05:01 PM
Brent Knarr's Avatar
Brent Knarr
1st Gear
Hey snake eyes I just bought a set of Bridgeport valve stems for my low rider wheels. My wheels only have a spot face on the inside of the wheel not on the outside. It looks like the valve stem only has a rubber gasket where it touches the outer part of the wheel. Any verification on this ? Or is there a inner and outer gasket with the valve stems.
Old Feb 22, 2023 | 05:12 PM
snake_eyes's Avatar
snake_eyes
The KurveyGirl stems only had O-rings on the outside also. IIRC the nut had a flared base that flattened against the inside of the rim and they recommended blue Loctite.
Edit: Yes, that's right. here's the diagram from their website
Old Feb 22, 2023 | 07:25 PM
Brent Knarr
1st Gear
Man I don't know what I was looking at earlier. My wheels do have a little boss on the outside for the valve stem. It's just not machined. Hopefully it still seals. Thank you for the reply.
Old Feb 23, 2023 | 08:31 AM
snake_eyes's Avatar
snake_eyes
Yeah, that's the same rim I am running. My are just powdered black.
TA0502
Engine Mechanical Topics
Nov 15, 2021 06:27 AM
kel03
Wheels/Tires
Jan 20, 2018 03:52 PM
*JC*
Wheels/Tires
Sep 5, 2016 06:44 PM
46u
Exhaust System Topics
Jul 10, 2013 08:07 AM
dkitch
Aug 12, 2009 04:05 PM
