7mm To 5/16 Stem Valve Conversion?
Old Nov 12, 2021 | 02:54 PM
TA0502's Avatar
TA0502
6th Gear
Default 7mm To 5/16 Stem Valve Conversion?
So I'm porting & polishing a set of heads for my 96ci to throw on when I do the 107ci big bore. I'm reading a bit about upgrading from the 7mm stem valves to a 5/16 stem and was just wondering if basically all that's needed is to order 99-04 guides/seals/springs & valves?
Old Nov 12, 2021 | 03:41 PM
marcodarq's Avatar
marcodarq
this is not an upgrade. it should only be considered if you are going p to a 2.00 or larger intake valve on a maximum effort build.
m
Old Nov 12, 2021 | 04:01 PM
TA0502's Avatar
TA0502
6th Gear
So there's not a while lot of point of going to 5/16 even if you're changing out everything anyway? I just noticed that both Fuelmoto and Zippers list 5/16 valves in their 1.9/1.61 heads, that's what size valves I'm going with so I was debating stepping up the stem size.
Old Nov 12, 2021 | 07:33 PM
Ed Ramberger's Avatar
Ed Ramberger
Thicker stem is just more mass to control. The 7mm valve uses a beehive spring which further reduces reciprocating mass as opposed to double sprung 5/16 valves.
Old Nov 13, 2021 | 07:44 AM
wfolarry's Avatar
wfolarry
I don't consider going to a 5/16 valve an upgrade either.
Old Nov 13, 2021 | 12:17 PM
Max Headflow's Avatar
Max Headflow
On 06 up heads, you can get a good 20% improvement on them but boring the intake seat out about 0.020, a little clean up and AVnV 1.850 intake valves. Need to recut the seat to center on the valve and outside cut 37 deg. Don't polish the intake port. You'll loose laminar flow. Stay with 7mm.
Old Nov 13, 2021 | 12:27 PM
TwiZted Biker's Avatar
TwiZted Biker
7mm = .2755" , 5/16" = .3125", as been mentioned unless this is a max effort build there is a lot of money & labor involved for little gain on a daily rider.
Old Nov 13, 2021 | 04:35 PM
TA0502's Avatar
TA0502
6th Gear
Sounds good, thanks for the input everyone. I know generally you're after a lighter valve train but wasn't sure if the change was related to rigidity. I'll order everything for a 7mm set up and call it a day.
Old Nov 15, 2021 | 06:27 AM
prodrag1320's Avatar
prodrag1320
this makes no sence at all,stick with the 7mm parts
max738
Engine Mechanical Topics
11
Jun 23, 2022 03:07 PM
02fastdyna
Sep 17, 2015 10:40 AM
Lamy1
Exhaust System Topics
Oct 24, 2013 11:29 AM
keywestwillie
Aug 5, 2011 12:44 PM
jeffwoods1962
Shovelhead
16
Feb 16, 2011 09:32 PM
