Primary Bolt Depth
Old Jan 11, 2023 | 07:32 AM
snake_eyes's Avatar
snake_eyes
Originally Posted by NEWROADSTER
Call those guys, they will fix you up quickly. I called them and got the exact bolts that fit my bike.
It was included in the engine kits I bought....
As mentioned by NEWROADSTER, call them, they should be able to hook you up....
I shot them an email and they sent me a quote which was almost double the cost of the bolts from Summit Racing. An, awesome, longtime member here offered to turn them on a lathe as a favor, so I am g-to-g. Thanks, guys, for the input.
Old Jan 11, 2023 | 08:29 AM
Bailey78's Avatar
Bailey78
Originally Posted by snake_eyes
I want to switch out my primary hardware with ARP 12pt bolts. The spec from the MoCo says that the shorter bolts are 1/4-20 x 1 3/8" but ARP doesn't make one. Can I safely drop in a 1/ 1/2" bolt? Has anyone done that?
An easy way to gauge it is to pull a bolt out stick a piece of wire in there see how deep the hole is if you got the clearance go for it if not well do what someone else suggested cut the end of the bolt off dress it up make sure to run a chaser on it and there you go
Old Jan 11, 2023 | 10:06 AM
Blue Bob's Avatar
Blue Bob
How deep the threads go.
Old Jan 11, 2023 | 01:34 PM
GREENOHAWK69's Avatar
GREENOHAWK69
Why not remove one of those bolts and try the longer bolt and see if it fits.
picciuca33
Apr 27, 2020 07:58 AM
thewoozel666
EVO
18
Mar 10, 2020 08:08 AM
Syris71
Aug 26, 2012 07:08 PM
parakiller
Apr 27, 2009 10:33 PM
shooter5501
General Topics/Tech Tips
Apr 23, 2008 01:42 AM
