Which screws for front engine mount isolator?
Old May 17, 2023 | 05:55 AM
geter712's Avatar
geter712
Default Which screws for front engine mount isolator?
Hi guys!
What is the measure of front isolator screw (2 pieces) which hold front engine mount - isolator to the frame??? Are those 3/8 UNC thread??
I'm gonna experiment a bit with shimming my front engine mount isolator as well as to shave a bit of upper rubber parts, to see if I can get some improvements on engine vibrations. For that, I need to order longer isolator screws, but I'm a bit unfamiliar with imperial screws, so a bit of help could be useful
Old May 17, 2023 | 06:55 AM
ppilotmike's Avatar
ppilotmike
Originally Posted by geter712
Hi guys!
According to my 2003 Dyna P/N they are 3/8-16 x 1-1/8 inch, grade 8 bolts.
Old May 17, 2023 | 07:21 AM
geter712's Avatar
geter712
Thats what I thought. Will order the same but longer. Thanks!
Old May 17, 2023 | 08:11 AM
John CC's Avatar
John CC
When the front mount sags it pushes the engine back against the rear mount, causing the rear mount to "sag" horizontally. Shimming the front mount is not the answer...
hardheaded
May 19, 2021 10:29 AM
ditchbanger
Jul 12, 2015 08:57 PM
OLD 96
Aug 6, 2014 09:04 AM
fortune
Apr 29, 2010 03:54 PM
russell6hp
Mar 24, 2010 05:55 AM
