Dyna Alignment
https://www.hdforums.com/forum/dyna-...ine-brace.html
edit: I never had to touch, adjust or do anything to the top link.
It sounds like you're saying the engine and swing arm are not in line with the frame and forks, since you say you have to set the rear axle on an angle to get it to track right. If after replacing both mounts and adjusting the top link, you still have that problem, you need to figure out what is pushing the engine and swing arm out of line with the rest of the frame.
The top link is only to get both wheels vertical at the same time and should not push the whole engine left or right.
It seems that you want to align the rear wheel horizontally, but are under the assumption that somehow motor mounts are involved (or should be involved) in this process. They are not. I am not an expert in rear wheel alignment but I'm sure someone on this forum can help with this.
Now for the real confusion. Looking at the book here, and also this video:
What I’m seeing here is this: adjusting the driveline to 90*, with frame at 0* using the link ensures the wheel/drivetrain is not tilted right or left, but is now straight up, and also allowing equal height on each shock mount (measurement from top bolt to bottom bolt. I’ve seen tools made for this, and using a large caliper to do the same) Adjusting the axle adjusters straightens the rear wheel to the frame and front wheel. If the rear and frame are set at 90* and 0*, and the inclinometer on the front wheel indicates other than 90, then something in the fork is off, and either it’s bent or the tubes are not level with each other. In that case you would fix that portion to make the front and rear 90* and the frame 0*. Now everything should be in alignment. Follow where I’m going with this? After doing this, then loosen the front and rear frame to mount bolts, start engine, at idle for a few, and let settle (releasing any mount tension), then shut down and torque the mount to frame bolts to book specs. Sorry this is so long, but best way I could explain what I’m seeing here. Any advice appreciated!
this is pretty much what I’m getting at, and why I thought the mounts might be causing my issue, and how to align it once the new mounts are up installed. The book shows how to replace them but does not say to align the bike after install. I know it’s probably something simple and I’m overthinking this, but want to get it right.
I think I understand what your saying about the rear wheel. If you stand the bike upright, and look at the rear wheel from the back of the bike. your saying that the top of the rear wheel is pointing to the left or right. As in the whole wheel is at an angle top to bottom in the frame. Also if the shocks were removed, one side of the frame to swing arm shock mount bolts would be a shorter distance than the other.
Since the swing arm on my '07 is attached to the back of the trans. If the engine top stabilizer tilted the top of the engine to one side or the other of center, it would also tilt the swing arm and wheel.
If your motor mounts are failing, it "MAY" allow the bottom of the engine to be out of center while the top is still center. This could make the rear wheel be at an angle. Just installing new mounts could solve your issue??
I'm new at this alignment thing. I'll be needing to change engine mounts in the near future, So I'm trying to learn something here. Please correct me if I'm wrong
Hope this helps,
Tom
Hope this helps,
Tom
with this noted, now I wonder why or how moving that top link aligns the front and rear wheels parallel. Seems to me it would only align them in the way your quote is bolded.
On a conventional frame the steering stem or headstock and the swing arm pivot are always orthogonal. The top link adjustment is for that purpose.
Don't make it more complex than it really is.
This is what is supposed to be accomplished by the LASER test:
NOT...that the front to back of the wheel is pointing left or right.
I do not understand as well as to how the top link would correct front to back alignment (Think Toe In)??? I do understand how "with perfect engine mounts and installed perfectly" the top link would change the top to bottom of the tire angle (Think Camber). I also could see that badly worn engine mounts could allow the bottom of the engine to be to one side or other of center allowing a top to bottom angle of the wheel.
Johns example to me says to move the axle on one side forward or back to get the front to back of the wheel as well as belt or chain alignment.
But.....Please correct me if I'm wrong.....If the front "OR" rear engine mount was severely worn/damaged and is allowing the engine/trans unit (front or rear of the engine/trans unit) to sit left or right of center (as in at an angle in the frame pointing left or right), that I think would also cause the rear wheel , front to back, to be pointed left or right (same direction as engine is pointing). Normally would be fixed with adjusting the axle provided the engine is sitting straight forward and back in the frame.
As a thought on what I just wrote. If the front of the engine and the front of the rear wheel were both pointing to the left of center of the frame (provided the axle is properly measured and even from the swing arm pivot or alignment marks on the swing arm), I think that the belt/chain alignment could be perfect. If I understand right, the engine and trans and the swing arm are essentially one unit. As in you could pull the assembly out and mount it on the back of a go cart and have a 3 wheel go cart.
Again, just some thoughts,
Tom
