Dyna Alignment
Old Aug 24, 2023 | 08:10 PM
  #31
John CC's Avatar
John CC
LASERs? Just get a couple of straight boards and duplicate the setup in the picture above. I've heard of folks using two 8 foot florescent tubes. Very straight, but a little on the fragile side for my tastes.
Old Aug 24, 2023 | 08:17 PM
  #32
John CC's Avatar
John CC
Technically, if your frame isn't bent, and your mounts are good and your swingarm to axle measurements are good, and you level the frame correctly, and the top link is set right, then the wheels will be centered between the boards..
Old Aug 27, 2023 | 03:14 PM
  #33
propflux01's Avatar
propflux01
Replaced both front and rear mounts. Aligned according to book and videos, and got a perfect 0*/90*/0* match. I can let go of the front and bike just goes straight as arrow. My assumption was rear mount was not working as it should. Everything, including axle distance, is now spot on. I have a leftover kinetic front mount, only installed and about 5-10 miles on it if anyone is interested. Pretty much brand new.
Old Jul 27, 2025 | 01:25 PM
  #34
Nickchesbro's Avatar
Nickchesbro
Stage I
Originally Posted by propflux01
John, I just cannot wrap my head around how the center link moves the whole assy to the center, as the picture you supplied shows, (and what the laser method does, as well). In Tom's bolded portion of the quote, he is thinking as I do, that centering the axle first, by doing the swingarm axle measurement would align the front and back wheels, and the link adjustment would set the 'camber', or tilt of the wheel, so to speak.. I don't understand why (in the video) first doing 90*/0* rear set, then adjusting the link again, as he does in the video to "set the laser alignment.. Why bother setting up the 'tilt' of the rear, just to keep moving it after you get it 90*/0* ?
The reason you can’t grasp that is because he’s not adjusting it AGAIN…. You see he isn’t working on a DYNA, he’s working on a bagger. The center link does the same on both models, but the baggers have another adjustable link on their front motor mount, which he is adjusting in that latter part of the video to align the lasers.
monchidog
EVO
15
Dec 6, 2021 05:39 AM
El Chiguete
Nov 9, 2021 05:58 PM
Dynaglide92
Sep 28, 2018 10:09 AM
hell hound
Apr 23, 2015 01:06 PM
jermil32
Ironhead
Sep 12, 2007 11:57 AM
