1995 Dyna, front engine mount bad ?
Old Aug 22, 2023 | 01:29 PM
KentuckyChristian's Avatar
KentuckyChristian
Default 1995 Dyna, front engine mount bad ?
Harley Davidson Forums
95 Dyna Convertible, broken engine mount?
Subscribed
KentuckyChristian , Today 09:49 AM
I've just noticed what seems to me as excessive engine vibration. To the point of denting my front exhaust, ( see pic).
The only thing I can think of is a worn out engine mount.
Before I replace it, I'm gonna make sure that it's snug n not vibrating loose.
It's the front mount I'm concerned about.
It's a 95, with only 6,100 miles on it.
My thinking is dry rot.
Not sure what else it could be at this point.
Any and all opinions/ suggestions are greatly appreciated.
Edit Quote Multi
Subscribed
Reply to Thread
Back to Subforum
1/1
Old Aug 22, 2023 | 01:41 PM
nevil's Avatar
nevil
Pics of the mount would be more helpful than the dented pipe, but it probably is the mount. Stock units are not expensive and as old as yours is I would say it's time to get a new one. I don't know what else could cause that unless you were in a wreck.
Old Aug 22, 2023 | 01:42 PM
GREENOHAWK69's Avatar
GREENOHAWK69
Pictures of the front engine mount would be better than the picture you uploaded.
Old Aug 22, 2023 | 08:36 PM
KentuckyChristian
No........no wreck that I'm aware of.😉
I'll post some pics of the mount tomorrow.
Thanx
Old Aug 22, 2023 | 09:03 PM
misfitJason's Avatar
misfitJason
Yes that's a failed mount. When your gap from your exhaust to your downtube is minimal, it's a sign of a failure.
Old Aug 23, 2023 | 07:58 AM
KentuckyChristian
I think I've decided to replace it with a Kinetic Structures mount.
A little costlier than most. But money well invested IMHO..
The exhaust dent isn't any cause for concern is it. Exhaust restriction etc.?
Old Aug 23, 2023 | 08:03 AM
pgrchaplain's Avatar
pgrchaplain
You need to replace Both Motor Mounts. There's an Alignment Procedure in the Service Manual.
Old Aug 23, 2023 | 02:32 PM
KentuckyChristian
Thought I would ( replace both). Rear needs to be installed before the front iirc.
KentuckyChristian
Feb 28, 2024 12:02 PM
St33da
May 3, 2019 11:27 AM
Banjo Mike
Apr 11, 2018 04:20 PM
Deathbat9
Jun 9, 2015 10:59 AM
