leakin brake fluid
Old Aug 24, 2007 | 11:49 PM
vinnypie's Avatar
vinnypie
Default leakin brake fluid
stopped for gas 20 min. into my ride and noticed fluid coming out of the resevoir. got home and took it off then put it back on. it's late so i won't be riding till tomorrow to check it out. should i be concerned, should i do something else? thanks vinny
Old Aug 25, 2007 | 03:34 AM
Qball's Avatar
Qball
Default RE: leakin brake fluid
I had a problem seeping out from the gasket on the handlebar. Warranty took care of it, they said it has been a problem.
Old Aug 25, 2007 | 07:07 AM
Psycho's Avatar
Psycho
ORIGINAL: vinnypie
Yes, you should very thoroughly clean any and every surface that the brake fluid has contacted. Stuff can wreck a paint job, eat insulation off of wires, and eat rubber mounts.
Old Aug 25, 2007 | 09:53 AM
HOGRIDA_06's Avatar
HOGRIDA_06
Could be caused by over tightening the cover. You just want the cover gasket to make contact. You don't want to squish the gasket or she'll leak for sure.
Old Aug 25, 2007 | 12:14 PM
pauletich's Avatar
pauletich
Clean it well, check the gasket and get a new one if need be. Make sure when you tighten it up its secure and not over tight.
Old Aug 25, 2007 | 01:13 PM
DeJavu's Avatar
DeJavu
Check your diaphram, it may have a pinhole. If its leaking around the seal you can clean and replace, If its leaking out the little breather hole in the cap, the diaphram is damaged and must be replaced. Note: if you're in the middle of nowhere, you can make a temporary diaphram out of a condom! Works great, worked so good I'm still riding on mine after 6 mons. Leave the old one on and ut the condom over it, pull it tight with the tip in the middle, the outer gasket will seal the edge and hold the condom in place.
Old Aug 25, 2007 | 02:32 PM
dlstanf2's Avatar
dlstanf2
The Svc Dept. at my LD left mine untightened, it leaked on a trip, and really screwed the finish of my cases. Black stains that will not come off.
Old Aug 25, 2007 | 11:07 PM
06dynablack's Avatar
06dynablack
It must be a warranty prob.Year ago mine starting leaking after i had the top switch cover ducttaped to it while changing grips shortley afterwards started leaking thought I had messed it up bought a new take off cover with gasket for 15 bucks.Roll clock ahead 15k miles notice it starting to seep at gasket again .WTH could be the deal with em I wonder?
jisananimal
Nov 30, 2011 08:19 PM
Mad Viking
Jul 27, 2010 02:55 PM
oinker02
Mar 20, 2009 08:54 PM
128auto
Jul 3, 2008 10:18 AM
TurkeyRun
Mar 17, 2008 10:25 PM
