leaks???
Old Nov 29, 2011 | 06:41 AM
jisananimal's Avatar
jisananimal
Default leaks???
i got a very tiny leak out of my front brake reservoir on my 2012 street bob...opened it up, lots of fluid but it jus dribbles out jus slightly when i ride...just wondering if this has happened 2 anyone else....thx
Old Nov 29, 2011 | 08:24 AM
Good_Apollo's Avatar
Good_Apollo
2012 probably still under warranty, I'd take it to the stealer
Old Nov 29, 2011 | 08:49 AM
cthagreekgod's Avatar
cthagreekgod
It never happened to me, but when the resevoir cap was put on, is it possible the the rubber "gasket" was put in incorrectly? I know on a previous bike of mine, the rubber was essentially inside out and was pushing into the fluid as opposed to staying above it. It's hard to explain, but if you see it is incorrect, you will know what I mean...
Old Nov 29, 2011 | 09:35 AM
07bobber's Avatar
07bobber
take it to the dealer, you cant just replace the gasket you have to replace the whole cover. make the stealer pay for it..
Old Nov 29, 2011 | 12:17 PM
bobnehoc's Avatar
bobnehoc
This happened on my 08 SB. Dealer replaced under warranty. My 07 Low Rider had the same issue and since it was not under warranty I wdnt to the dealer to buy a new gasket. It is a whole assembly, gasket and cap. $30 beans later it was repaired. Take yours back for warranty claim. Also since mine leaked under warranty they replaced the whole master cylinder as the brake fluid was eating the paint....
Old Nov 29, 2011 | 02:53 PM
jisananimal
thx 4 the input guys
Old Nov 29, 2011 | 07:38 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Keep in ind the screws holding the cap down are tighten to 8 INCH lbs., the rubber gasket barely bulges out.
Old Nov 30, 2011 | 04:23 AM
BoozerHi's Avatar
BoozerHi
Plus 1 on this. Over tight and it'll leak!
Old Nov 30, 2011 | 12:44 PM
Scuba10jdl's Avatar
Scuba10jdl
On the brake master cylinders, there are tiny little vent holes. They are small and are hard to see, but are there for a purpose.
If the brake fluid is very full it will sort of bubble/leak out of there until it lowers the level enough to not leak out. It's not a problem, but you just have to wipe it up to make sure it doesn't get on anything.
That's one reason I prefer DOT 5 over the others, no paint/plastic damage from the fluid.
Old Nov 30, 2011 | 08:19 PM
PigInaBlanket's Avatar
PigInaBlanket
Mine always leaks until I get the torque just right on the lid. I don't have a torque wrench to measure that small amount so I just have to play with it until it stops leaking. It isn't very tight when it's right and yea the gasket has a slight bulge to it.
mrperez
Sep 9, 2010 09:50 PM
aposto
Wheels/Tires
Aug 9, 2010 07:20 PM
TurkeyRun
May 8, 2009 12:12 PM
davidsdad
Sep 15, 2008 10:24 AM
vinnypie
Aug 25, 2007 11:07 PM
