Front signals
Old Aug 27, 2007 | 05:03 AM
larazauk's Avatar
larazauk
Default Front signals
Well guys, after taking your advice I decided to tackle the turn signal relocation myself, undid the two tank bolts, lifted the tank up a bit and fitted the kit without too many probs (not sure about the way they look though!).
Put it all back together and in order to get the loom cover tabs back in I lifted the tank a little bit more and guess what? I snapped the f***ing qd on the fuel line[:@]!!!! gas everywhere and a bike I can't ride until next weekend now[:@]
Live and learn I guess.
Old Aug 27, 2007 | 05:50 AM
dailydriver's Avatar
dailydriver
Default RE: Front signals
Butdo the directionals work? replace the fuel crossover and your still getting out cheaper than if the stealer did it...Plus now you know how far you can lift the tank before the quick connect breaks....Dude the Glass is half full
Old Aug 27, 2007 | 09:16 AM
pauletich's Avatar
pauletich
Live and learn, I have done things like this more often then not, but like dailydriver stated you got off cheaper then if had had a dealer do it.
I have also had the dealer do things like this on mine. That pi$$e$ me off even more then if I brake something.
Old Aug 27, 2007 | 10:22 AM
larazauk's Avatar
larazauk
ORIGINAL: dailydriver
Ha ha!
Old Aug 27, 2007 | 05:32 PM
TurkeyRun's Avatar
TurkeyRun
Sunday, I decided to go after installing my Drag Specialties layback license plate holder and turn signal relocation kit. Now, I had been working graveyard in a timezone 2 hours away all week, and flew in Saturday after working Friday night. I couldn't get to sleep and wen out into the garage (insert scary splatter-flick music). Been up 26 hours, took a two hour nap.
I needed to cut the leads to my turn signals. I remember thinking "ok, measure 3-4 times, think this through..." I had about three choices; cut near the light, cut in the middle, cut back toward the harness. I cut in the middle - mistake.
In the long run, it all worked out. A little crimping, some heat shrink, a cable tie, all seems well. It works, no sign of rubbing on the tire or anything. Sometimes, you just gotta break stuff to learn how to not break stuff.
NYCFXDC13
May 7, 2012 09:32 AM
RocketRocker
Aug 9, 2009 06:52 PM
jamesdeanblvd
Feb 9, 2009 11:49 AM
jjwin98
Sep 6, 2008 11:33 PM
dg7080
Feb 10, 2008 05:37 PM
