Engine/Security light flicker
Old Dec 10, 2023 | 02:34 PM
Mchad's Avatar
Mchad
Default Engine/Security light flicker
I was out riding today and after about an hour or so I noticed my security light came on, and the amber engine graphic flickered a couple times, then they both went out. I pulled over a couple minutes later and checked for codes, both on the speedo, and also on my PV. No codes.
’17 LRS
Any ideas?
Old Dec 10, 2023 | 03:09 PM
Paintslinger16's Avatar
Paintslinger16
Active Streak: 120 Days
I would check the battery connection and then test battery to rule that out
Old Dec 10, 2023 | 03:19 PM
Mchad's Avatar
Mchad
Yeah suppose so. It’s funny I was just being lectured by someone last night that batteries only last 2 years in Florida heat. I didn’t believe it. Maybe it’s true, mine is about 3…
Old Dec 10, 2023 | 03:46 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Check your FOB battery. A low voltage bike battery would set a code I believe.
Bike battery should be OK running unless the actual connection was loose or corroded.
If that was the case, you would get that grunt, hesitation or starter bang from kickback that's a sure sign of bad connections or worn-out battery when starting. In Florida or Boston.
Especially in Florida, don't keep it on the maintenance charger all the time. Just when it sits for weeks. That way, the last start you get at home will not hopefully be the last.
Old Dec 10, 2023 | 03:48 PM
Mchad's Avatar
Mchad
Originally Posted by Jackie Paper
Check your FOB battery. A low voltage battery would set a code I believe.
If that was the case, you would get that grunt, hesitation or starter bang from kickback that's a sure sign of bad connections or worn-out battery.
Right, but no codes. All I saw as said was the security light (red dot) light up for a few seconds, and while it was lit the yellow engine icon flickered a couple times before they both went dark. No codes present.
Edit: oh, you’re suggesting a low volt fob might cause it. Ok, will do
Old Dec 10, 2023 | 03:55 PM
Jackie Paper
Added a couple more points about what is what on battery and thoughts above.
Sorry.
eixiel
Electrical/Lighting/Alarm
Jun 9, 2023 11:42 AM
user 7172984932
Sep 8, 2019 08:24 PM
cweiss
Aug 21, 2012 03:05 PM
883 IRON
Aug 10, 2009 12:57 AM
jb bill
Dec 26, 2005 05:28 PM
