Jims axle lockdown dimensions
Old Dec 20, 2023 | 03:43 PM
scoop_fraser's Avatar
scoop_fraser
Default Jims axle lockdown dimensions
Just wondering if anyone has one of these kits. This would be for a 2000 FXD (Jims #1746). I can't find any retailers with stock so I was considering having a local machine shop make something up. If you have one of these I'm curious about certain dimensions.
Old Dec 24, 2023 | 05:05 AM
tar_snake's Avatar
tar_snake
The lockdown washer looks more like a gimmick than anything. Unless you're building a drag bike, IMHO the stock crown nut works just fine.
As for the end plate adjuster things, I used these in the link for my '98 FXD and they're fantastic compared to the stock crap.
https://www.bungking.com/chain-belt-tensioner-plates/
Old Dec 24, 2023 | 09:53 AM
scoop_fraser
Thanks for the link! I see that TCBros makes something similar. The thing I don't like about the stock, flat washer under the castle nut is how concave it ends up. As that washer flexes and changes shape the axle nut torque loosens.
Old Dec 25, 2023 | 09:22 PM
Blue Bob's Avatar
Blue Bob
I am a machine shop in the Atlanta Ga area. Shop rate is $125 an hour. $100.00 hr minimum. Just saying this is a typical metro area rate.
Check with your local and post back.
Old Dec 26, 2023 | 09:44 AM
tar_snake's Avatar
tar_snake
IMHO, in my years of working on my sleds, if you're warping that washer, you're torquing it more than it's supposed to be. Besides, even if you're not, you can head to Lowes and get a thicker washer for a couple bucks and it'll work perfectly. I just hate to see you blowing your scratch on something that's way too costly when there's something that's far cheaper that'll work just as well.
Old Dec 26, 2023 | 11:10 AM
Max Headflow's Avatar
Max Headflow
The plates are 1"x2" with say a 0.080 step on the inside. 3/16 to 1/4 inch thick. The swing arm is standard 1 x 2 box tube. Probably 1018..
The washer is probably 1/8 inch thick. OD maybe 1 1/8 to 1 1/4 with say a 0.760-0.780 hole in the middle. The protrusion is about 0.062 thick.
I made a set of stainless steel ones about 12 years ago.
Old Jan 3, 2024 | 08:48 PM
Max Headflow
Changed the rear tire yesterday on my FXDX..
Old Jan 4, 2024 | 10:32 AM
2500hdon37s's Avatar
2500hdon37s
Check out the Bare knuckle axle adjusters. Bare Knuckle axle adjusters
thedawkter
Oct 14, 2021 08:48 AM
05dlx
Sep 20, 2019 07:26 PM
Nelz
17
Jan 13, 2019 02:28 PM
NightTrainRob
Mar 25, 2014 11:39 AM
tigger26976
Apr 26, 2012 04:40 PM
