Yep that's the one ... you should ask them about the price difference. Although they sometimes are not real responsive.
So the reversed one above uses no Fork Stops?
EDIT: Interestingly, There are 3 part#s for the DE-RAKE kits and only 1 for the RAKE kit
Yes, the de-rake kit too has a fork stop, but it is on the other side of the lower cup. If I would use the normal kit mounted backwards the fork stop lug fill be facing backwards too and not be of any use.
"On the other hand during hard braking there would be forces trying to flip the cups when used in the "rake out" position, that would not appear in the de-rake position."
Good point! 👍
And, as it looks like you found someone who designed them for de-rake, even better.
Just wondering what the procedure is to get them in correct "timing" if I can use that word here. Or clocked into correct position... 🤔
Good point! 👍
Yeah, that worries me a bit too. I have found some instructions online and they basically say "make sure the cups are aligned correctly and press them into place.."
I am pretty sure I will be able to mess that up pretty badly
