05 lowrider fxdl code issues
Old Jun 19, 2024 | 05:55 PM
paulmedford's Avatar
paulmedford
if its a carb bike, clean the carb, check the petcock and tank for debris, change the inline fuel filer if you have one. Sounds like it can run the fuel fast enough
Old Jun 19, 2024 | 07:22 PM
Willys72's Avatar
Willys72
2nd Gear
Originally Posted by Jackie Paper
Does it have a carburetor? Maybe a fuelpump you hear for couple seconds when you first key on?
Yes it is carbureted and I hear the pump come on I took it for a spin and it still sputters 1352 1355 still comes on
Old Jun 19, 2024 | 07:37 PM
Harley_ish's Avatar
Harley_ish
Originally Posted by Willys72
Yes it is carbureted and I hear the pump come on ...
Very Contradictory on that ffxl
Old Jun 19, 2024 | 08:15 PM
TexasScooterTrash's Avatar
TexasScooterTrash
deleted
Old Jun 19, 2024 | 08:21 PM
paulmedford
guess its not a carbed bike lol, if its injected fuel pressure check and fuel filter check
Old Jun 19, 2024 | 08:56 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Only the FI has a fuelpump.
Old Jun 20, 2024 | 06:40 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
FXDL indicates a carb engine, if you are using the enrichener, that has to be pushed back in or it WILL foul the plugs and the engine will eventually die, usually in a couple of miles.
Old Jun 21, 2024 | 05:44 PM
Willys72's Avatar
Willys72
2nd Gear
I do not know where that is or if I am using the enrichener
Old Jun 21, 2024 | 06:20 PM
paulmedford
like a choke... a little lever or cable to pull
Billy North
Sep 12, 2016 08:34 PM
Toon1
Apr 21, 2016 03:59 AM
dolg
Jun 29, 2015 02:56 AM
FLHP1034ME
46
Jun 16, 2010 08:05 AM
