For a quick diagnosis you can pull the oil pressure relief spring #13 in the diagram above and stretch it out a little and reinstall to see if the light goes out hot at Idle. It might even increase your off idle pressures but will not increase flow.
Also, it's very possible your idle is too low (950-1000 rpm is recommended). And use 20w-50 Dino oil.
750 rpm is too slow of an idle speed for an Evo. The factory service manual calls for an idle speed of 950-1050 rpm when the engine is at operating temperature.
