ELECTRICAL HELP NEEDED
Old Sep 4, 2007 | 07:48 PM
Spanish Flyer's Avatar
Spanish Flyer
Default ELECTRICAL HELP NEEDED
Dear Friends,
Yesterday I installed the left-hand chromed lever, chromed clutch lever
support and the also chromed switch gear housing and even the chromed
buttons. All went well and went for a ride, but it looked a bit ridiculous
with one side of each. Of course horn, indicators and everything was working fine
This evening I decided to do the brake side my only concern being not to
spill any brake fluid when changing to the chromed master cylinder. Once I
did that, I started removing the old black switch gear casing; the rest was
the same as the left hand side, but decided to put the bike on the lift this
time since by then my back was killing me. It was then, when I went to start
the bike that the rear pilot light was not on, the brake light did not work,
the indicators were also dead and the horn didn't work; I think that's about
it, because I do have head light I can change Hi-Low, instruments are
illuminated and the bike primes and starts.....
Must be some silly thing, but don't even know where to start looking.
By the way all fuses are Ok (pulling one out made the alarm go off for about
5 minutes on and off) where the hell is that little siren so I can put a
pillow over it (he, he..) it's 2:30 am here in España!![:@]
Pleaseguys tell me something so I know where to look. By the way even though the
indicators don't work in the normal mode, when the alarm is reset all light
up..
Any ideas?
Old Sep 5, 2007 | 07:03 AM
mizzourider's Avatar
mizzourider
Default RE: ELECTRICAL HELP NEEDED
I just replaced my bars. I have a similiar problem. Headlight works, dim and bright. I have no turn indicators, break indicator, or horn. Hope somebody has an idea?
TC
Old Sep 5, 2007 | 07:07 AM
Softy's Avatar
Softy
ORIGINAL: mizzourider
TC
Oh Dear...Have you checked your fuses?
Old Sep 5, 2007 | 07:11 AM
Softy's Avatar
Softy
ORIGINAL: Spanish Flyer
Dear Friends,
up..
Any ideas?
Take the right side apart again. You have cut a wire or pulled one out. The two wires from the brake switch,one is yellow? I think...,anyway,it's common with the orange wire with white tracer.All the orange wires with white tracer need to be hooked together. Let us know what you find.
Old Sep 5, 2007 | 07:29 AM
Z_Stingray's Avatar
Z_Stingray
You definately have a blown fuse and a shorted wire. Open up the switch housing and carefully check the wires. Look for any sign of a cut, rub, anything that might expose the wire. If you detect anything cover it with tape or silicone sealant. Also, place pieces of cardboard or rubber under the wires to shield them from the metal switch housing. That way, if you do have or get a short, it won't ground out with the housing. Check the fuses carefully. If that stuff isn't working, there has to be a short somewhere that popped a fuse.
Old Sep 5, 2007 | 01:03 PM
Spanish Flyer
Jesus! can't you ever be wrong?
Thanks guys, in the end it was the accessory fuse blown, number 11 on the Dyna manual. Of course, finding the fuse is one thing and the other the short that caused it. It was fine before I started so for sure I was to blame somehow or other. It ended being the left hand switch gear; could find nothing wrong or pinched wires, but as I left it hanging without touching the bike the 5 amp fuse wire I use when I'm confronted with such happenings stopped blowing (I put a hair sized made for that purpose copper wire across the fuse pins). Anyway, I peeled the plastic cover far enough, checked all wires that fit inside and as I say found nothing. Put it back together and now it is fine. I hate those repairs where you cannot find the real cause because they can reappear in the worst moment you can think of. As for Mizzourider, I would look in the same place and get youself some of that 5 amp wire, so you don't keep burning new fuses and because 5 amp puts much less strain on your electrical system. You can also use a tester, but mine was dead ( I left it on a year ago...).[:'(]Oh one other thing, due to the problem I was not able to disarm the alarm, so I just disconnected the battery and let it scream till the module had no juice left. Now I have to reconfigure it [:@][:@]
Old Sep 5, 2007 | 05:24 PM
mizzourider
WOW, came home from work, popped the fuse box open. With no faith, looked through the fuses- and what do you know, I was thrilled when the "accessory" fuse was blown!
Was afraid I would have to tear the bike apart looking for the connectors that were messed up from my bar exchange!
Thanks all,
Tim
Old Sep 6, 2007 | 12:37 AM
Softy's Avatar
Softy
You're welcome.
Old Sep 6, 2007 | 02:23 AM
traveler's Avatar
traveler
Yea, Glad to hear all went well. For future reference...when these things happen, it means that the wire with power going through it is touching metal/ground. Sometimes a "jiggle" on the wire is enough to free it....to get home, or ride until it happens again. Glad "Softy" was able to help you, before I got to this thread. Don't you fellas love this site?
~Joe
Medicbearusaf
Jul 26, 2017 09:40 AM
LWOS
Apr 1, 2014 12:40 PM
theosmithers
Electrical/Lighting/Alarm
Jun 13, 2009 01:08 AM
jester12
Oct 31, 2008 11:51 PM
Naz_Man
Dec 16, 2006 05:57 PM
