Big bored and now hard starting
Old Apr 21, 2025 | 06:14 AM
sorensentyler's Avatar
sorensentyler
Default Big bored and now hard starting
Question for you. I have a 2007 street bob. I put 255se cams in it with big bore cylinders (3.875) and high compression se pistons. Put compression releases in the heads. Before I did the work the bike started fine. Now it struggles to start even when I push the compression releases in. I have a base power vision tune, when it's running it kind of coughs. Runs like crap, probably need a dyno tune. I don't understand why it starts so hard. Almost like the starter isn't big enough or not getting enough fuel (injectors)? Ignition issue?
Old Apr 21, 2025 | 06:25 AM
Rounders's Avatar
Rounders
A tune might help. When I built my 2007 last year to to 103 I purpopesly stayed away from high compression .035 head gasket and MR103s. You will probably have more power than me though. I didn't do compression releases
But if it runs bad you need a syno or another tune to get closer. What did you tune it with so far?
Old Apr 21, 2025 | 07:03 AM
sorensentyler
i emailed powervision and told them what I was running. They sent me a base tune for that. I have a dyno scheduled for may 1. We’ll see what happens.
Old Apr 21, 2025 | 07:04 AM
TexasScooterTrash's Avatar
TexasScooterTrash
With my 07 Dyna, SE255's, 105" 10.5:1 top end, mild porting, EFI to Miluni HSR 42 started very slow. Put in Hi Torque starter. Problem Solved.
Old Apr 21, 2025 | 07:18 AM
Paintslinger16's Avatar
Paintslinger16
Active Streak: 120 Days
Test the battery, and check all the connections, the CCA for the stock motor is being exceeded, and if it’s never been replaced you also have a 18 year old starter, which also may be weak.
somewhere between the Battery, connectors or starter you probably will find the issue.
Old Apr 21, 2025 | 07:27 AM
sorensentyler
battery is brand new. All the connections are tight. I’m leaning towards the starter.
Old Apr 21, 2025 | 07:43 AM
garystaven88's Avatar
garystaven88
What’s your cranking pressure each cylinder out of curiosity..
Old Apr 21, 2025 | 07:52 AM
Hey Man's Avatar
Hey Man
How's the condition of the battery? High compression requires high cold cranking amps. If you aren't over 300 fuggedabodit.
Old Apr 21, 2025 | 12:12 PM
sorensentyler
brand new battery with great cca
Old Apr 21, 2025 | 12:13 PM
sorensentyler
just checked, 190-195 both cylinders. I fired the bike up without using the compression releases and it had no issues 🤷‍♂️
