Hunting grounds
Old May 5, 2025 | 11:47 PM
randallissimo's Avatar
randallissimo
Default Hunting grounds
Working on a tail light issue. All rear lights terminate to an 8 slot AMP connector under the seat that connects to the harness. I believe everything on the lights side of the connector is good. Slots 4, 5 and 8 house black ground wires. The schematic shows these three connected together on the harness side of the connector, with one wire going to a ground stud that has already been addressed. . It's late and it's dark, and I can't see much down in there at the moment.
My question is, how would one expect those three ground wires to be connected? Wire jumpers, wire nuts, or ? Two of the grounds seem fine, I want to get a look at how the third one is connected.
Old May 6, 2025 | 04:11 AM
eighteight's Avatar
eighteight
Originally Posted by randallissimo
, wire nuts, ? .
Please do not use wire nuts .
Old May 6, 2025 | 10:10 AM
pgrchaplain's Avatar
pgrchaplain
Solder and Heat Shrink Tube.
randallissimo
No one is considering using wire nuts. Just wondering how the factory joins harness grounds before going to frame.
Old May 7, 2025 | 11:05 PM
randallissimo
So the three black ground wires from the connector under the seat come out of the harness way down in the abyss. They are terminated with crimp-on ring connectors and fasten to the frame with a small mounting bolt behind the electrical panel. Two wires were crimped to the same ring, the other had it's own.
Hated that ground scheme so I made a new one by drilling a 3/8" hole next to a weld on the electrical backing plate. Ground off the paint, used toothed SS washers, and red loctite bolted a SS 1-1/4" long bolt/nut with enough sticking out to be a ground stud. Works great.
doo925
Mar 26, 2016 10:23 AM
mstrobes
2014-2024 Touring Models
Jun 27, 2015 09:44 PM
GoofySB
Jun 4, 2014 10:24 AM
Toliverpeterson
Sep 3, 2012 11:07 AM
WARG
Oct 18, 2010 09:22 PM
