Stripped oil drain plug hole
Old Jun 4, 2025 | 05:19 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by Rounders
What words would you add surfer boy?
Typical outcome of any thread that you infest, you tell stories about yourself and your imaginary motorcycle experiences and end up sparring with other posters.
OP: Before you take certain posters seriously, look at their posting history and you will see that some are only here to disrupt.
Old Jun 4, 2025 | 06:49 PM
Uncle Larry's Avatar
Uncle Larry
^^^ Good advice to heed to ^^;
Old Jun 4, 2025 | 08:34 PM
golfblues's Avatar
golfblues
Do a Google search for a Colony brand oversized drain plug for your bike. This happened to a friend of mine and I got the colony plug and re-drilled and tapped the hole using plenty of grease on the drill and tap to capture the shavings. We used some deck furniture cushions and laid the bike on top of them on its side and drilled the new hole. Tapped it and that was 4 years ago and all is good. Be sure to flush any shavings left behind out with cheap oil.
I don't know if this is the right one for your bike but it will give you an idea of what you're looking for
Old Jun 4, 2025 | 09:00 PM
John CC's Avatar
John CC
Remember, the topic is "Stripped oil drain plug hole"
Old Jun 5, 2025 | 05:55 AM
Bass Player's Avatar
Bass Player
"Rounders" is the best "troll" we have. The closest thing he owns that even resembles a motorcycle is the "word" motorcycle. Not sure that's even right?
Old Jun 5, 2025 | 07:35 AM
Crabchuck's Avatar
Crabchuck
Teflon tape is unaffected by gas or oil.
Not all. The stuff I used to seal up a spout on a fuel can turned to goo.
Old Jun 5, 2025 | 07:45 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Teflon tape is not affected by gas or oil, it has been used in the automotive and industrial world for decades for this purpose, that is a fact.
Old Jun 5, 2025 | 09:18 AM
Goose_NC's Avatar
Goose_NC
Is all Teflon tape the same?
Old Jun 5, 2025 | 09:37 AM
Uncle Larry
Old Jun 5, 2025 | 10:02 AM
malfvnction's Avatar
malfvnction
Originally Posted by HD_noobie
It sounds like it still tightens down.
use a magnet in the hole after tapping.
The pan is cast aluminum, not magnetic.
