Stripped oil drain plug hole
Old Jul 6, 2025 | 07:46 PM
  #51
Harley_ish's Avatar
Harley_ish
Originally Posted by John CC
The problem with Teflon tape in gasoline (or anything else for that matter) is, if you undo the fitting with the Teflon tape you are left with thousands of threads of Teflon that can get into whatever it is you're trying to seal. Not so bad for a kitchen faucet but very bad for a fuel lubrication system..
Should have just let the O-ring do it's job. It's not a thread seal application
Old Jul 6, 2025 | 07:57 PM
  #52
John CC's Avatar
John CC
Next time you pull the drain plug out, remove all the tape fragments from the plug and as much as you can from the hole. With a little luck all the fragments you don't (can't) get will end up in the filter. Reassemble without tape. An o-ring doesn't need any help sealing. If you're sealing a pipe thread, use thread dope.
Teflon tape is for plumbers.
Old Jul 6, 2025 | 09:01 PM
  #53
randallissimo's Avatar
randallissimo
I'm pretty meticulous about these things, and since I know I didn't overdo it, I'm really not worried about it. But I understand some feel otherwise.
Old Jul 7, 2025 | 05:31 AM
  #54
Rains2much's Avatar
Rains2much
Sorry didn’t read the entire thread so excuse me if it’s redundant, but skimming I saw Teflon tape mentioned a number of times.. (I know this is stripped) but in the practice of using tape it might be helpful to know there is such a thing as heavy duty tape.. and it can make a huge difference. It’s thicker and stickier. I like to use it. Might try it when traditional tape doesn’t stop a leak. It’s a band-aid but can get you by for a while before you address the issue properly.
Amazon Amazon
aces&8s
Exhaust System Topics
11
Sep 9, 2013 04:42 PM
jamala00
Mar 24, 2012 03:10 PM
thunderchild223
May 30, 2011 09:31 PM
Tonefiend
Oil Archive (no new posts)
Sep 26, 2010 09:04 AM
RednekF350
Apr 25, 2009 07:44 PM
