Every since INDOT did some construction on the road i took to work and eventually ground the road down without any warning to anybody, I now getting a clunk noise when I go over bumps and potholes after hitting that transition from ground pavement back to normal pavement.
Originally i was suspecting the jarring uneven pavement finally did my(presumably original) engine mounts in, my coworker thinks my suspensions needs rebuilt/replaced.
The most likely suspects would be the engine mounts and gas tank. Inspect the mounts, they've probably on there for a long time. Put a socket on the tank bolts and make sure they're tight.
Check your steering head bearing first. A worn bearing is a common cause of that clunk over bumps. Also inspect your swingarm pivot bearings and shock mounts.
