Jump starting your Harley
Old May 25, 2026 | 03:13 PM
flyboyron's Avatar
flyboyron
Default Jump starting your Harley
I could not find a thread about what the procedure is for jump starting your bike if it has a CAN Bus system.
Some say it is ok to jump at the starter, some say no, others say only 22 and newer bikes shouldn't be jumped.
What is the real scoop on this topic?
Old May 25, 2026 | 03:18 PM
Rounders's Avatar
Rounders
Harley sells a jump pack
Old May 25, 2026 | 04:47 PM
Jackie Paper's Avatar
Jackie Paper
Harley does not recommend and says it there top of page, but it realizes sometimes it may be necessary in a real emergency.
If your absolutely certain your battery is OK and just low from leaving lights on, then it's OK to jump it. Just hook it directly to the battery and then the frame ground.
Should have the jumping vehicle off.
If there is any question that there is a issue, jumping it to start it and there is a issue with battery, it could damage the regulator trying to charge a bad battery.
Maybe even damage the stator inside the primary buried behind the chain and compensator.
That is a big dollar fix.
I would not ever jump a Harley at home. Put it on the maintenance charger and charge it.
I would not do it away unless you consider the risk is worth the cost.
PS. We have been round and round with this..
Look it up in your owners manual. Its under Battery. It's there blow by blow order to hookup and unhook.
Old May 25, 2026 | 05:09 PM
Oldat81's Avatar
Oldat81
Motorcycle Battery jump starter pack. Harley, Antigravity, Battery Tender.
Positive to Starter Negative to Frame
Old May 26, 2026 | 01:43 PM
snake_eyes's Avatar
snake_eyes
I carry one of these specifically for my wife's '22 FXBBS. I run a lithium battery so I can't use it, but I'm also not worried about needing a jump.
Booster Portable Battery Pack | Harley-Davidson USA
Old May 26, 2026 | 01:46 PM
Rounders's Avatar
Rounders
Originally Posted by snake_eyes
I but I'm also not worried about needing a jump.
Booster PortableSA
Everything breaks down sooner or later
Old May 26, 2026 | 03:46 PM
John CC's Avatar
John CC
I'm sorry, but they sure are proud of that logo! That's a Noco GB40 with Harley logos on it. I paid about $80 for mine...
They're freekin' awesome! I can jump my Mercedes 4 cylinder Diesel 3 or 4 times without having to recharge it.
[Edit] Looks like they're up to about $100 now.
Old May 26, 2026 | 03:48 PM
Rounders's Avatar
Rounders
The have gone up a lot the last 5?7 years. But does have some tax on it
Old May 26, 2026 | 03:55 PM
snake_eyes's Avatar
snake_eyes
Originally Posted by John CC
I'm sorry, but they sure are proud of that logo! That's a Noco GB-40 with Harley logos on it. I paid about $80 for mine...
Yup, you're right. I forgot Noco sells it for ~$100. I didn't know that until after I bought mine, oh well. It does work with all the Noco accessories, I have this NOCO - Boost Eyelet Cable w/X-Connect Adapter - GBC007 permanently mounted to the wife's bike under the seat, so it's a simple plug-in of the booster if needed. I also bring the booster into the places we stop to eat and use it to recharge our PacTalk headsets.
Old May 26, 2026 | 04:00 PM
Rounders's Avatar
Rounders
I added pigtail to one bike. You need to make you get right style ends. The one I bought came with adapter for tender
Thought might be annoying to put them on every time. Could tape the tender adapter on
Not sure why this is dyna section
