Please help, am I riding wrong???
Old Sep 21, 2007 | 08:01 AM
R Racing's Avatar
R Racing
Default RE: Please help, am I riding wrong???
I have sever carpo tunnel in both hands, I find using a good gloves with gel padding helps hugely for me.
Jim
[/align]
Old Sep 21, 2007 | 08:03 AM
voyager1's Avatar
voyager1
Try some better grips and get some gel gloves.
Old Sep 21, 2007 | 08:04 AM
jimsreddyna's Avatar
jimsreddyna
Second the Kuryakyn ISO Grips. I still get the sleeping finger thing once in a while on a long ride. Say 2 hrs in the saddle of straight cruising with no stops, gear changes or any other reason to move my hands around.
Give them a try. They work and they dress up the look at the same time.
Old Sep 21, 2007 | 09:04 AM
emillisk's Avatar
emillisk
Try a throttle boss
helped for me on longer trips
Old Sep 21, 2007 | 09:05 AM
efciv's Avatar
efciv
Throttle Rocker or Cramp Buster sure helped me.
Old Sep 21, 2007 | 09:12 AM
Chipstah's Avatar
Chipstah
I found after putting on polyurethane riser bushings (which allow more vibes to travel up the bars) my right hand tended to go a bit numb until I realized I was gripping the throttle too tight - as soon as I relaxed my grip when cruising it went a way - and gel gloves help, too.
Chip
Old Sep 21, 2007 | 09:21 AM
allengator's Avatar
allengator
I had that problem until I realized my right glove was too tight...
I like snug fitting work gloves, so I thought my riding gloves fit great...
I got one size larger and now it is much better.....
Old Sep 21, 2007 | 09:46 AM
rockdoc's Avatar
rockdoc
I third the Iso grips and gel gloves. Mine used to do it quite a bit but stopped after the Iso grips were installed. Plus they look good too.
Old Sep 21, 2007 | 09:59 AM
pauletich's Avatar
pauletich
ORIGINAL: NightBob
You could be riding wrong, seriously.
Look at your wrist position. If you are riding with your wrists angle upward so that your hands approach the grips from above, then you are probably restricting the circulation to your fingers. It's really tempting to ride this way, especially with ape hangers. It kind of looks cool; it kind of feels cool. Until your fingers fall off, then, not so cool.
Try to keep your wrists straight.
I agree, make sure your wrists are in the correct position.
Old Sep 21, 2007 | 10:40 AM
BULLDOG88's Avatar
BULLDOG88
Good posture can help.
keep you elbows in/down.
take off any large rings.
