rear pulley-except 06 dyna
Old Sep 26, 2007 | 09:17 PM
DyNaMc's Avatar
DyNaMc
Default rear pulley-except 06 dyna
Does anyone know what makes the rear pulley on 06 dynas unique?Why doesn't a 07 one work. Is it the distance off the wheel? If so can spacers fix it? Or the bolt pattern? If I change wheels will that help selection? I have done most of my work by trial and error, only to find it addressed later in the forums.I do use a wrench for a living so I can deal with beyond bolt-on. I thought I'd get smart and ask before I start yanking stuff off and buying things, this time.I DO know it is a 1 1/8 in belt. 70 tooth i believe, which is common to many other rides. I asked the Chrome Consultant at the local but he was no help. I really dont want to buy a cover or even factory Moco stuff. Not when there are so many wild choices out there. I have checked JP etc. for the guy who has that answer. Theres something unique to 06 and I want to find out what it is. Thats all. I realize I can throw a lot of $$$ at it and there would be solutions
I will probably change out to a 18 x 5.5in wheel later. Bike is 06 FXDI. Thanks guys
Old Sep 26, 2007 | 09:24 PM
dlstanf2's Avatar
dlstanf2
Default RE: rear pulley-except 06 dyna
The 07 has a different tooth pulley.
Old Sep 26, 2007 | 09:38 PM
DyNaMc's Avatar
DyNaMc
Yes I think a 66 tooth. But why dont 70 tooth 1 1/8 pulleys work? I guess I kind of rambled. Thats my ? in a nutshell
Old Sep 27, 2007 | 07:08 AM
2007fxdc's Avatar
2007fxdc
Didn't they go to a narrower belt in 07? Could that be related to why as well?
Old Sep 27, 2007 | 07:52 AM
man4mopar's Avatar
man4mopar
I think it would work BUT. It would change your speed and odometer calibration, you will probably notice the final gear change too. Other then all that I bet it would work fine.
Old Sep 27, 2007 | 12:07 PM
dmoore35_1999's Avatar
dmoore35_1999
I'm not sure which one is more narrow, the 06 or the 07, but that is the difference. I basically had to get my whole rear end replaced because the bolts on the pulley backed out and f#$%ed up a lot of sh&t back there. The dealer took an 07 off the floor to replace the parts which all fit and were ok untill the actual pulley. He told me there is about an 1/8th to a 1/4" difference in the pulleys, so they ordered a replacement for my 07.
Old Sep 27, 2007 | 07:39 PM
jackyl's Avatar
jackyl
could be thinner pulley belt, smaller diameter or more or less tooth count. jackyl
Old Sep 27, 2007 | 08:06 PM
txtec's Avatar
txtec
07 and 08 is a 1 inch 68 tooth pulley
Old Sep 28, 2007 | 07:28 AM
tbone52's Avatar
tbone52
3/4 in. front axle - '00-'03 Dyna
3/4 in. rear axle - '00-'05 Dyna
1 in. front axle - '04-'07 Dyna (except '04-'05 FXDWG)
1 in. rear axle - '06-'07 Dyna
25mm front axle - '08 Dyna (except FXWDG and FXDF)
25mm rear axle - '08 Dyna (except FXDF)
3/4 in. front axle - '00-'05 FXDWG
blackmopar
Apr 4, 2012 04:46 PM
paul s
Dec 6, 2009 06:34 PM
HOGRIDA_06
Mar 2, 2009 01:35 PM
sniper77
Dec 13, 2008 09:23 AM
356rider
Jun 27, 2007 03:36 PM
