Exhaust Baffles
Old Oct 10, 2007 | 03:17 PM
Livi1215's Avatar
Livi1215
Default Exhaust Baffles
Lookin for a little help. I punched the baffles through on the stock slip ons,then had the download and air cleaner upgrade done. One of the baffles was rattling around so I took it out now I can't seem to get the other one out as easy,any suggestions.
[IMG]local://upfiles/43000/7293E14F503F4854A6E7A9D97F70781F.jpg[/IMG]
Old Oct 10, 2007 | 03:28 PM
rockstar_josh's Avatar
rockstar_josh
Default RE: Exhaust Baffles
How did you do the first one? I guess you could use a dowel rod or something similar, and a hammer. Stand the pipe straight up, hammer the dowel rod down onto the baffle until it pops out.
Old Oct 10, 2007 | 03:34 PM
Livi1215's Avatar
Livi1215
A dowel rod? I'm not sure what that is,it sounds familiar. I am wondering if maybe it might have a spot weld on it or something.
Old Oct 10, 2007 | 03:54 PM
rockstar_josh
A dowel rod is just a round stick of wood, used for home projects and stuff. Anything like thatthat's soft enough you won't risk damaginganything, you know? I don't think the baffles are spot-welded in. A lot of people have taken their's out on this board - maybe you can find some tips by searching.
Old Oct 10, 2007 | 04:11 PM
Livi1215's Avatar
Livi1215
Yeah. It's not welded I got it to move a little. I think the other one just rattled around and broke loose thats why it came out so easy. This one is being a pain. Thanks for the input, I tried a bigger piece of wood and had no luck. I think maybe if I grind a piece of metal stock down to bite the wall inside, I don't know.
Old Oct 10, 2007 | 04:43 PM
DougsDyna's Avatar
DougsDyna
1 1/4" hole saw, and drill it out. Don't go beating your mufflers up.
DougJ
Old Oct 10, 2007 | 05:39 PM
Livi1215's Avatar
Livi1215
Thanks I got it. Damn thing had 3 spot welds on it. We used the handle to the floor jack and beat the hell out of it. Appreciate the help.
Inderblitz
May 31, 2017 08:26 AM
jimlowe
Feb 8, 2014 01:37 PM
bloomington g
May 29, 2010 10:48 PM
fishhead57
Nov 5, 2008 08:11 PM
Axholio
Jan 29, 2006 01:17 AM
