Changing pipes soon - Anything else needed?
Old Oct 17, 2007 | 06:30 PM
AdrianVall's Avatar
AdrianVall
Default Changing pipes soon - Anything else needed?
Hey all,
As some of you have been reading, I will be ordering a new set of pipes fairly soon, wether it be slip ons, or a complete exhaust system. Now, what my question is, are there any other modifications that need to be done in? For instance, any sort of fuel management system or tuning or anything of the sort? I see some talk about a race tuner or stage 1, or SE a/c.. I'm completely confused!
Hope to hear from you all,
Cheers,
Adrian
Old Oct 17, 2007 | 06:37 PM
Mr E's Avatar
Mr E
Default RE: Changing pipes soon - Anything else needed?
Adrian,
Depending on your fuel delivery system (carb or injected) changes will be needed.
You will want to put a breather kit on, this lets more are in.
If you are carbeurated you will need to rejet the carb.
If you are injected you will need to adress the fuel managment system (remap).
Changing the amount of air let in and the ease of exhaust flowwing out makes the carb or map changes necesary.
Hope this helps.
Mark
Old Oct 17, 2007 | 08:03 PM
AdrianVall's Avatar
AdrianVall
Thanks Mark! Appreciate the quick response.
I ride an 06' Streetbob, so I believe itsfuel injected. Now, whats it going to take to do this remapping? Am I going to have to take this to the bike shop to get this done? Or would I be able to do this myself..
Any breather kits that you would reccomend for my Streetbob??
Cheers,
Adrian
Old Oct 17, 2007 | 08:08 PM
itileman's Avatar
itileman
A simple K&N filter should suffice. You can go fancy and expensive with a hypercharger, but aren't going to get much more air in than with the K&N. You're going to pay for looks.
Old Oct 17, 2007 | 09:16 PM
JayFromPa's Avatar
JayFromPa
Bigger A/C means more air into the motor which menas your motor need more fuel. You bike is F/I so you need to have a remap done to your ecm by a shop or buy an aftermarket tuner such as a Thundermax or Dynojet and so on and do it yourself.
Do some searches on tuners and you will come up with a ton of threads devoted to this.
Old Oct 18, 2007 | 04:00 PM
AdrianVall's Avatar
AdrianVall
Approximately how much does this remapping cost? What have you all spent on doing this?
Old Oct 18, 2007 | 04:30 PM
Mr E's Avatar
Mr E
You will want to put ona high flow back plate . This allows more air to flow to the filter.
The stealer can install and set up the ECM for you.
Old Oct 18, 2007 | 04:35 PM
max290's Avatar
max290
It will cost you roughtly about 6 to $700 for the SE Air kit and the SERT. Plus Dyno and labor...You may be able to get the SERT and/or air kit cheaper on Ebay...Maybe!!
Old Oct 18, 2007 | 05:45 PM
labfreak's Avatar
labfreak
ORIGINAL: AdrianVall
K&N filter and mount about $60.00 and a stg 1 download is about $150.. thats what I did, plus cycleshack slip-ons and I run fine now for 5000 mi.
Old Oct 18, 2007 | 06:50 PM
DGlide04's Avatar
DGlide04
I'd recommend some other basic and unglamorous stuff while you're at it like new exhaust gaskets, a new set of retaining rings and 4 new exhaust stud nuts because these little things get rusty and all of the shiny things in the world won't help much if the pipes leak or can't be put on because you don't have the nuts to tighten the new pipes down with. Make sure the mounting studs aren't too rusty or crossthreaded when you get the old pipes off.
NewfieRocker
Dec 5, 2009 08:34 AM
ELGOLD
Apr 22, 2009 07:53 PM
edtexas
Apr 1, 2008 03:47 PM
usdave1t
Nov 17, 2007 06:35 PM
alabama1
Apr 25, 2006 09:04 AM
