popping and sputtering while idling
Old Oct 17, 2007 | 09:28 PM
maddoggreene's Avatar
maddoggreene
Default popping and sputtering while idling
Anyone had this problem? When its cold-my '04 Wide glide sputters pops revs and sometimes dies while idling. After I take off it seems to run fine--no codes showing up--my local dealer has had the bike for a month now and is scratching his head. He called the MOCO and they're scratching too! Any ideas?
Old Oct 18, 2007 | 01:27 AM
SpringerDude's Avatar
SpringerDude
Default RE: popping and sputtering while idling
Is the bike warm? If so, it sounds like it's idling too low. Just a guess.
Old Oct 18, 2007 | 08:41 AM
PoCoBob's Avatar
PoCoBob
Had a car once that liked to rev on it's own when idling. Turned out to be an air leak in the intake system. Take a spray bottle full of water and while it's idling spray all the areas were there is a gasket. If there is a leak the engine will react when you spray the areawith the leak.
Old Oct 18, 2007 | 11:57 AM
01harleygal's Avatar
01harleygal
My dyna was doing that also. Trailered it to the dealership and they changed the intake gaskets,wasn't them. It ended up that it was a fuel line chaffed in the tank. Of course you can't just buy the line, you have it get the whole fuel pump assembly.
Just tell your mechanic to look at the fuel line in the tank.
I hope this helps.
Old Oct 18, 2007 | 06:19 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
is the bike carbed or efi? if it's efi does this happen on a full tank? if not maybe 01harleygal is on to something. as the fuel level drops down it's sucking air or it's not delivering full fuel pressure. if it's a carbed bike are you remembering to push in the enrichener ****? just some thoughts.
Old Oct 21, 2007 | 07:41 AM
01harleygal
Maddoggreene, please get back to us with what the problem was, so the rest of us would know what to do if it happened to us.
I hope your mechanic found the problem with your bike.
Old Aug 30, 2008 | 03:49 AM
kuleli's Avatar
kuleli
hi
I have the same problem. when it is cold bike dies then accelaretes suddenly. it was so strange. I went to hd tech and he test drove it. he said fuel pump went out. they just replaced one recently on a streeb bob. so they cured the disease. now I left my bike in my garage for 15 days waiting new fuel pump. it is not recommended to ride the bike in this way I told.
hope this helps
06 wide glide
Old Aug 30, 2008 | 06:32 AM
tramp's Avatar
tramp
is a 04 carbed?
Old Aug 31, 2008 | 02:42 AM
WildBill76's Avatar
WildBill76
Make sure when you pump your gas, it is amber in color. Where I live the gas stations had a common supplier. ( Different Brands Though ) Well ! I don't know why but, the premium storage tanks ended up with E85 in them. ( None of the stations have E85 Pumps ) E85 will really make a EFI Bike run weird. Missing on light loads, and acting like the bike was running out of gas.
Notgrownup
27
Sep 10, 2022 05:46 PM
just plain john
General Topics/Tech Tips
16
Dec 10, 2020 10:28 PM
brihvac
Nov 24, 2010 04:33 PM
tgarrett1
Jul 8, 2009 08:53 AM
crock921
Sep 26, 2007 10:49 PM
