Paging Ben Riden
Old Oct 25, 2007 | 10:45 PM
ss377's Avatar
ss377
Default Paging Ben Riden
Did you find out what caused you miss/sputtering on your St Bob?
Old Oct 28, 2007 | 06:27 AM
Ben Riden's Avatar
Ben Riden
Default RE: Paging Ben Riden
Not yet, but it did finally do it while the service manager was riding it, so nowhe knows the syptoms hopefully it will be found and corrected soon. Are you having a problem with yours?
Bob
Old Oct 28, 2007 | 06:46 AM
Oilslick's Avatar
Oilslick
My bike did this. Rear cylinder misfire, gradually got worse over many months. Tried usual stuff. Eventually got really bad and threw up code 'rear injector open / low'
Turned out the wiring to the rear injector had broken inside the insulation. Check continuity between power feed from coil to injector plug and from ECU connector and plug. Wiggle wire while doing this as wire can touch or not.
Harness is tight here not allowing for enough movement of the rubber mount motor. I pieced it out and used heat proof sleeving over the top.
Might be nothing to do with your problem but just another angle.
Old Oct 29, 2007 | 05:02 AM
Ben Riden's Avatar
Ben Riden
Thanks for the reply, I'll check that out.
Bob
Old Oct 29, 2007 | 10:45 PM
ss377's Avatar
ss377
Yes, mine was/is doing the same thing. It's at the shop now. Service manager told me the same thing Oilslick said. They finally got a codes on the rear injector and the throttle position sensor. The wire cable is short and taut. Vibration could have broken the wire somewhere. They are trying to track the break down. I'll post the results.
Rubline
Electrical/Lighting/Alarm
Aug 26, 2016 05:33 AM
jimdads
Jul 31, 2016 03:51 PM
man4mopar
Apr 18, 2009 12:07 AM
ss377
Dec 16, 2007 05:54 PM
ss377
Nov 18, 2007 12:15 PM
