need help with shocks
Old Oct 31, 2007 | 03:20 PM
Chipstah's Avatar
Chipstah
Default RE: need help with shocks
ORIGINAL: Rebel Ryder
11" will drop it real low. might want to consider 11.5 or 12 to compensate for your weight (compression)
412's are cheap its the 440's that'll break the bank. consider adding front lowering springs too.
not being a prune, but do a search - tons of info on this exact topic! good luck
My thoughts exactly.
Chip
Old Oct 31, 2007 | 03:32 PM
TOMMAY's Avatar
TOMMAY
I think the 412's would work for you. Get the heavy duties.
I weigh 240 and run mine on the lightest setting with no problem even with a sweat hog on the back that gotta be pushing the total close to 400.Mind you the ride will be very stiff with the heavy duties but you get used to dodging pot holes.Now if you pick up a little dumplin' that weighs and much as you,I just don't know. The shocks might be ok but the frame might bend.
Good Luck
Tom
jambo1989
Nov 17, 2016 03:40 PM
iamrockinrich
Nov 29, 2012 06:12 PM
fireman36
Jun 1, 2010 03:53 AM
loyolacub68
Jan 11, 2009 07:17 PM
mercury
Aug 12, 2007 03:14 PM
