A slight exhaust problem
Old Nov 9, 2007 | 02:57 PM
longboarder's Avatar
longboarder
Default A slight exhaust problem
Well winter approaches andI was trying different ideas for riding pants and well my snowboarding pants keep me warm on the slopes.... unfortunatly while keeping me warm on my ride in to work part of the pant leg melted to the exhaust. Any ideas on removing molten goo from exhausts?
Old Nov 9, 2007 | 03:01 PM
extech's Avatar
extech
Default RE: A slight exhaust problem
Believe it or not try wadding up some aluminum foil and rub it on the area the melted stuff is.
Old Nov 9, 2007 | 03:12 PM
wkdavistx's Avatar
wkdavistx
When I get my ol' lady's shoe sole melted to my pipes I just leave it alone until it bakes off. If finally will bake to a crisp and come right off.
Old Nov 9, 2007 | 03:46 PM
2007fxdc's Avatar
2007fxdc
Try getting it off after you get the pipes hot again. Be careful though and be sure to use a clean cloth. If it's truly "goo", try some goo-gone (not on hot pipes LOL).
Old Nov 9, 2007 | 04:57 PM
Low_Wider's Avatar
Low_Wider
Long,
Did the same thing a while back. read the boards and most recommended was acetone or oven cleaner. Used the acetone and it worked real well. Good Luck.
Old Nov 9, 2007 | 05:03 PM
JRK5892's Avatar
JRK5892
do not let it bake off it will stain the chrome (in most cases) do not use steel whool it will ruin the chrome... some gys ahve some old school tricks that work great! do a search
Old Nov 9, 2007 | 05:49 PM
bikerdog134's Avatar
bikerdog134
i had a plastic grocery bag melt on mine. i was able to peel it off when it was cold
Old Nov 9, 2007 | 07:09 PM
DougsDyna's Avatar
DougsDyna
peel off what you can cold/hot, and when pipes cold spray some WD40 on the remainder. Chrome Polish will clean up the rest....
Many of the suggestion here will work, just don't use anything abrasive.
Snowboarding pant will wrk better, if you can fit them under some chaps.
DougJ
Old Nov 11, 2007 | 10:49 AM
longboarder
Thanks for the info guys..... I ended ridng around to heat the pipes and then used 'goof off' to clean the gunk . Thanks again
Diverrick
Jun 11, 2019 08:26 AM
BobberG
Sep 26, 2014 06:51 PM
Jlajoie03
Aug 20, 2012 08:28 PM
ryanbradshaw
Exhaust System Topics
Jun 20, 2011 08:44 PM
evilscotsman
Aug 1, 2007 06:49 PM
